Feigao magnet let go
Shark413
Shark413's Avatar
Feigao magnet let go - 08.25.2007, 02:37 AM
I posted that my Feigao 8XL magnet separated after a few laps around my local track. I have some updates so I am reposting here. I finally got my hands on some Loctite #638 so I applied the Loctite and made a jig to hold the magnet steady while the Loctite set. I used JB Weld on the end cap and between the two magnets. I have it back in my truggy and will try it out this weekend. I hope it holds up because I have 4 Feigao motors and I hear this happens a lot.
Separated magnets, shaft, bushing and magnet end cap.
Rotor clamped to keep the magnets aligned while the Loctite sets.
Serum
Serum's Avatar
08.25.2007, 02:41 AM
How did you aligned the rotor? with the magnets being pushed away from eachother?
Shark413
Shark413's Avatar
08.27.2007, 01:05 AM
Serum, it was actually a two-man job. After I put the Loctite #638 on the shaft and inside the magnet (hole) I slipped my alignment tool (basically a big spacer I made from some scrap) over the shaft and clamped the rotor in a vise, snug but not so snug that I could not turn the two magnets. Then using the black line on the two magnets (placed there by the factory) I turned the magnets until the black lines matched up. Then as I held them in place my brother tightened the vise so that everything was pretty much locked into place. I left it that way for 24 hours, then I removed it from the vise, cleaned it up, glued the end piece on with JB Weld and let it cure for another 24 hours. I put everything back together and put the motor back into my truggy. I ran it a bit around the backyard and it felt the same as before (power wise). I still need to give it a good work out at the track to see if it holds up.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
08.27.2007, 02:07 AM
That's odd, my 540C 7XL came as a 3 section rotor/magnet. How old is your motor?
Shark413
Shark413's Avatar
08.27.2007, 12:33 PM
I bought the motor from RC-Monster about 2 or 3 months ago. May be the 7XL needs 3 magnets (smaller) because of the higher rpm?
cemetery gates
08.27.2007, 12:44 PM
It is odd that your 8xl has only 2 magnets. My 9xl has 3 and other feigao xl rotors I've seen have 3 magnets...
08.27.2007, 01:19 PM
Yeah, my Wanderer 9XL and 10XL both have three segments. My 9XL is about the same age, maybe a tad older, but I can't remember now. Maybe it's something specific to the Feigao's, or maybe just the finned versions?
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
08.28.2007, 07:54 PM
My finned 8xl had two segments and I bought it about a month ago. I guess it would be better to get the smooth canned xl motors because 3 segments of equal length seem like they would more consistant than 1 short segment and 1 long segment.
Area 52 Ranch Raceway
T.R.C.R.
cemetery gates
08.28.2007, 08:03 PM
My 9xl was the finned version and it had the 3 magnets, so I don't think that it is only for the moth can motors. It seems like only 8xl motors have 2 magnets...
Bye
