CRT.5 Bruushless 1:12th ompetition indoor truggy
Thomas P
Talking CRT.5 Bruushless 1:12th ompetition indoor truggy - 10.03.2007, 10:51 AM
Finaly it is done...will only use this one for indor use..since the 1:10 wd car is little to big for our track, this will fit perect.
MEGA pinions
RC-Monster Motormount
GTB
7.5r motor SIntred
E-Power 2s Lipo 3600 20-30c (190 grams)
Done...
I tested this one, just this morning with 6 cells, ELITE 3600mah Nimh the car have GREAT torque, topspeed is perfect for the indoor track... will pick up my Lipos in a hour or 2..3600mah 2s 20-30 series from E-Power... Painted body, and a finish truck will come this weekend.
  Send a message via MSN to Thomas P
jnev
jnev's Avatar
10.03.2007, 07:00 PM
Looks great!! Seems to me that you have got a perfect spot for a square battery pack right behind the ESC.
rchippie
rchippie's Avatar
10.03.2007, 07:09 PM
Please keep us up dated on how the NOVAK system works for you. I have intertaned using a novak system if i was to convert my crt.5.
REAL MEN RUN BRUSHLESS
david lamontagn
10.03.2007, 07:19 PM
I want to remove my nitro engine and re-install a brushless in mine too, but i've a feigao 8s can, and i think to buy a 7.4v 3700mAh flightpower li-po, but not certain about a 7.4 volts setup in this truck.
Is i'll get a good power and good runtime I've always had 3s or 4s system, don't know anymore about 2s setup.
Thomas P
10.04.2007, 11:17 AM
Update.. Nitro is fun, but cant use that indoor :D... Talked to a machine guy(orwhat ya call i) he works with metall and CNC etc... he will DO a carbonfibre chassi for me, and a front bulkhead in Dural alu, Alu 2024...
Will post pics later on that, just bought the carbonfibre plate.. Costy as XXXX FG´s 3x150x350 mm
The little ive tested the car, say app 2-3 min full trottle away then back, the pack wasnt warm..the motor cold... GTB/7.5r Sintred
Thomas P
10.07.2007, 09:23 AM
So i did some tracktime...4 packs after packs, the motor temp wasnt higher then 33 deg celcius, Lipo 37 and ESC 20..th car reached topspeed after app 3 meters...il go up one more T on pinion t 14T for outdoor usae..indoor il think this combo will be perfect
Short run only testing...
