HV4.5 motor with mamba max esc and 4s?
Revracer
Revracer's Avatar
HV4.5 motor with mamba max esc and 4s? - 11.29.2007, 08:07 PM
i was looking at the novak HV 4.5 motor. how would it run with 4s lipo and the mamba max esc? should i just get the feigao instead?
entjoles
11.29.2007, 08:31 PM
i have done this same set up... in a g3r revo
my exp. was this, on 4s it cogged, it was still usable but not track worthy, the esc. also ran a little hot, caused by the cogging (???)
in my crt .5 on 3s it cogged very little and was way fast and powerfull, but it is very light compared to a mt
what is your setup???
if using a stock chassis and 2spd revo trans (requires a servo for brakes) it should be better because of the lower gearing of 1st gear
but i am not quite sure i would recomend this setup, you could try it, but if you need to buy the parts..... its up to you
Revracer
Revracer's Avatar
11.29.2007, 08:33 PM
it will be with stock tranny. if it coggs then i dont wanna deal with it. thanks. how about feigao? good on a 3s?
entjoles
11.29.2007, 09:26 PM
for 3s you will need a higher kv motor...
but i dont know how it will run, never ran that set up
drkros3
11.30.2007, 04:51 AM
hey wait i thught that the novak 4.5 motor was sensored. and the mamba esc is not a sensored esc.
or can you still run it with out pluging that wire into anything.
11.30.2007, 07:21 AM
correct it just runs sensorless...
entjoles
11.30.2007, 04:23 PM
now that i think about it, it would probably run good with the mm, if using the stock trans and 2spd
i never got a chance to test these in my 1st revo version
Serum
Serum's Avatar
11.30.2007, 04:34 PM
you can run a sensored motor on a sensorless controller. not the other way around though.
Revracer
Revracer's Avatar
11.30.2007, 04:50 PM
you can run sensored motors on the sensorless speed controls. so you think a MM and the 4.5 would be good on a 4s pack? or do you think the HV system would be better?
