lutach
lutach's Avatar
04.02.2008, 06:53 PM
Originally Posted by BashOn View Post
I'm running Reduce RPM. My truck is down for the moment but I am going to give cutoff a run on my next outing. I am quite sure that it isn't going to cutoff. Just looking at the data on the software I can see that the controller is allowing full throttle output, which it never had before. It will be a week or two before I get a replacement hybrid bulk from FLM though...
Could you also try using the controller's brake just to see if the issue on braking is gone?
Regards.
david lamontagn
04.02.2008, 06:55 PM
OK thank you.
My MBX5T is almost done, just the RCM batterie tray spacer to instal and get some good Velcro to secure the MGM to the custom mount that i've did, and i'll be ready for a first li-po cherge!
I just recieve my MGM 16018 with the new SW, so i'll reprogram all my End point and i'll try it in reduce rpm too.
For the brake, same thing for me, i've install mechanical brake on my truggy.
BashOn
04.02.2008, 11:56 PM
Regards.
My trans isn't locked so the motor brake won't work.
Is this something I could test just by seeing what the motor does when I use the motor brake? For example are you wanting me to see if it goes into reverse when I hit the brake?
lutach
lutach's Avatar
04.03.2008, 03:57 AM
The issue that I have when my controller is set for forward/brake only is when I apply the brake instead of braking it throttles up. The more throttle I give the stronger the throttle up is when I try to apply the brakes. It does this as well when forward/brake/reverse parameters are programmed too. I don't want you to break anything though.
Desmo
04.03.2008, 08:36 PM
what does it do when you apply forward?
lutach
lutach's Avatar
04.03.2008, 09:05 PM
It goes forward fine, but when you apply the brakes it accelarates forward instead of braking.
ncalenda
Need for Speed
ncalenda's Avatar
04.03.2008, 11:13 PM
do you have another motor around? Try that to see if it clears up the problem, I had that happen and the motor was bad.
Also, try to auto-tune, but you may have already tried that.
  Send a message via AIM to ncalenda
lutach
lutach's Avatar
04.03.2008, 11:42 PM
The motor is not bad. I'm using it without an issue with my Sculze 40.160.
david lamontagn
04.03.2008, 11:58 PM
Have you try to change the neutral zone on the controller? Try to put an higher number....Sound like you r controller don't see the neutral zone between the change from fwd to rev.
lutach
lutach's Avatar
04.04.2008, 12:01 AM
Yes, that was one of the first thing Mr. Grisa asked me to do. I might just send the controllers to MGM and get the latest FW.
david lamontagn
04.04.2008, 12:10 AM
Why?? you don't have the new SW in it now?
lutach
lutach's Avatar
04.04.2008, 01:07 AM
Got it a while back.
potreinas
04.04.2008, 10:22 AM
I have some news to you and all mgm users that have this issue, it accelerates when you try to brake, mine only did this in4 or more poles like neu or align 600xl...
This is my story:
- Problem 1: First I had a 12018 (3.14) that does glitch all the time (instant braking while accelerating or brake all the time).
- Solution 1: MGM changed it for a 9032 (3.21) (paying the difference :) )
second part:
- Problem 2: the new 9032 accelerates while I'm trying to brake, but as you know only with 4 or more pole motors, with feigaos the esc worked perfect.
- Solution 2: sended the 9032 with a align 600xl motor to MGM to show them the issues.
Today I have receibed my REPAIRED MGM 9032 (3.22), MGM told me by e-mail:
"Problem was in defective processor. Rare case"
so... its not the problem of radio, receiver, battery, connectors, motor, etc... it was a defective component of the esc, so...
lutach, you have to send it to them, tell them my case, because it seems to be the same problem. This esc seems to work ok, it brakes PERFECT with the align 600xl motor, feigao, and neu motors :) this is 3.22 firmware.
If you have any question let me know and I'll asq you.
This weekend I'll test it to see if it's perfect or don't work perfect.
lutach
lutach's Avatar
04.04.2008, 10:42 AM
This is my story:
second part:
Thank you. I will send them all then to get the new 3.22 firmware.
Countryhick
04.04.2008, 08:38 PM
This is my story:
second part:
Do you know if the problem will be solved by just updating to the latest firmware? Or is everyone that has this problem [quote] "Problem was in defective processor. Rare case." I have just got my stuff back from MGM and don't feel like sending it away for a few more weeks.
Cheers Andrew
