05.15.2008, 04:04 PM
Originally Posted by jzemaxx
Wow that sucker really goes!
hmm, but you think the weight savings would be anything worth moving to the l or xl?
05.15.2008, 04:05 PM
I personally think the bigger the motor the better. Less stress, less heat.
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
05.15.2008, 04:15 PM
Hmmm.... i should have kept my 8xl :D
05.15.2008, 04:22 PM
my friend run with a 5700 kv(mamba) on 11,1 volt  it was a rocket set-up  and the motor never reach over 130F
WARNING: May become violent.
05.15.2008, 04:39 PM
Not to bash you but that is pretty hard to beleive. CM36S series motors are one of the more sensitive motors to gearing and unless you have gearing down to a perfect match i just dont see getting those temps are feasible. All the CM36S series motors that Ive seen ran hot to extremely hot no matter how you geared them.
RIP- Tammy (9/14/08)
05.15.2008, 04:49 PM
with this set-up bashing its the only way to have fun....but its really true  ..nerver over temp the motor ,the pack and the esc.....curiusly the only thing he broke it is the front bearing on the motor  and the second speed,,,
05.15.2008, 05:39 PM
Well Takedown showed me a sweet little motor, its the Ammo 36-56... just a hair under the size of an xl, its like an anorexic xl...... the kv is 1800. Hey anyone out there can u tell me whats the tallest gearing that can fit on a Jato? Right now with the 1800kv 25/54 and 5s on 4.1" tires its only making 64mph.. thinking of getting a 7xl like Jzeemax said.. less stress on the motor.. and its 2383kv with the same gearing its pushing almost 80mph!!!!
so depending on if someone buys/trades the raze i might start work on this one...
05.15.2008, 07:46 PM
80mph is pure insanity at its heart. Hitting past 65mph will be difficult to control let alone not crash. I say setup first with a low gearing setup then gear up.
05.15.2008, 07:56 PM
I dont think controlling it would be a problem.. Not to gloat but i think im an alright driver, i can probably handle it
05.15.2008, 08:06 PM
Go to mod 1 pinions, you can go to 25/40, or maybe even smaller spurs, depending on motor to tranny clearance.
05.15.2008, 09:01 PM
I agree with TD, it sure is fun to run at the high speeds but its rather a surprise if I dont break something after a run, I have been going through front end parts mostly now...I have broken a set of RPM caster blocks...I have a set of AL ones on order from Mike.....also I have been using a set of Ananconda tires...thay are a bit too grippy for my tastes, I think I might go back to the solid foams I was running earlier my stance is as wide as they are with the Traxxas wheels but there is no tire ballooning
05.15.2008, 09:18 PM
Well i can always gear it for bashing and occasionally for speed runs
05.15.2008, 09:34 PM
According to traxxas i can fit a 20/40 gearing setup on this thing... that opens quite a few doors...
05.16.2008, 07:36 AM
OK maybe i Lied, I just put my pride and joy on ebay A 1990 Yz125..... if it sells i might get a medusa or equivelant...
If your interested its got:
New Piston and Rings
New Bore
New Main bearings and Seals
Only 5hrs on the new components....
anyways.....
If i do get a decent amount for it, what SHOULd i get?
hehe, a Lehner xl2400....
Its looking like either a Feigao 10/11L or the Nue 1512/2d
or still possibly the MR 36-50-2200
Reason: added info
