40T Revo spur gear in new style Emaxx, what pinions reach?
Cain
40T Revo spur gear in new style Emaxx, what pinions reach? - 05.16.2008, 01:35 PM
Hi,
Looking to put a Revo mod1 40T spur gear in a newer style emaxx, but I am not sure what pinions will reach ( using a Neu 1512 2.5D/F Motor).
What is the smallest pinion that anyone has used that will reach.
Or, if this won't work and I need a bigger gear, are there other options out there for a larger spur that will work on a stock newer style emaxx? (I read MGT, but can't see the pic someone posted).
If you know what the lowest pinion that will reach for the 40T revo spur, as well as the MGT spurs that can be made to work please post.
crazyjr
crazyjr's Avatar
05.16.2008, 03:26 PM
The 40t spur is a bit too small for the Emaxx/E revo's. I don't think the pinions will reach. I know the associated Mgt plastic spurs (mod-1) will fit the bolt pattern, you might can drill them to set in the slipper like the traxxas gears. i know the MGT spurs are close in size to the traxxas Emaxx/E-revo spur size
Prozac
05.20.2008, 05:50 PM
pretty much the same question I asked. I have a 16tooth on the way, its biggest I could find. I will try it with any of the emaxx/Jato spurs to try to get it to fit. I am thinking that with finned cans like ours the motor itself limits travel. That is going to be the limiting factor. No answer on whether or not the single motor mount has more adjustment either.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
05.20.2008, 09:36 PM
single mount doesnt have any extra travel! To use a 40t spur you'd need like 30t pinion, LOL, but seriously it won't work. If you want mod1 ur only option is the MGT gears. I did the mod but have went back to 32p gears because there are more options and the spurs are cheaper than pinion gears!
rhylsadar
rhylsadar's Avatar
05.21.2008, 02:11 PM
hi
here a pic of a modded mgt spur.
bye
rhylsadar
______________________
Exercitatio artem paravit
rhylsadar at youtube
mod1
rommel
mod1 - 06.19.2008, 11:06 AM
Originally Posted by rhylsadar View Post
hi
bye
rhylsadar
hi i really want to do this spur/pinion modification on my E (3905), currently im running novak hv pro 6.5 the one with 5mm shaft on 14/68t 32pitch 12cell 4200 eastpower batt...but im just curious if am going on the mod1 set-up what spur/pinion combo can you recommend to obtain mid 30mph to 40mph speed...i know mod 1 pinion and spur is far my much better compared to 32pitch set up... by the way what system are you running and how many tooth of spur and pinion are you using?
bruce750i
bruce750i's Avatar
06.19.2008, 11:17 AM
Imo 32p does the job. mod1 is for the old guys that can't see very well, so they can set the mesh.
