Originally Posted by tallyram
no, i need to know how to figure how many amps a pack puts out using the other supplied specs from the pack(c-rating, voltage, and mah). some manufacturers don't give you the number of amps, but give you a c-rating.
I have to agree with what azjc said and there are other good 25-30C options. Get the highest mAh pack that will fit your application. The only way to get more info, is to read what most people are using and view some of the datas posted in the forum. Get yourself a Eagle Tree or a BNB Products data recorder.
Edit: You can multiply the C rating with the A (5000mAh=5A) and you will have your AMP for that pack. Just remember there are packs out in the market that claims a high C rating, but they can't come close to it.
