tallyram
tallyram's Avatar
05.18.2008, 09:29 PM
no, i need to know how to figure how many amps a pack puts out using the other supplied specs from the pack(c-rating, voltage, and mah). some manufacturers don't give you the number of amps, but give you a c-rating.
luxury!
  Send a message via AIM to tallyram
lutach
lutach's Avatar
05.18.2008, 09:35 PM
I have to agree with what azjc said and there are other good 25-30C options. Get the highest mAh pack that will fit your application. The only way to get more info, is to read what most people are using and view some of the datas posted in the forum. Get yourself a Eagle Tree or a BNB Products data recorder.
Edit: You can multiply the C rating with the A (5000mAh=5A) and you will have your AMP for that pack. Just remember there are packs out in the market that claims a high C rating, but they can't come close to it.
05.18.2008, 09:52 PM
Amp rating is based on c rating and mah capacity.
Usually the battery is rated at continuous and burst, continuous is what you should focus on.
Take the mah (milliamp hours) of the battery and divide by 1000 to get ah (amp hours).
Then multiply the ah by the c rating and you have the amp output.
So say we have a 5000mah 20c continuous lipo. 5000/1000=5, 5x20=100amps.
This gets you close, and always factor a 20-25% margin. So if you think you need 80amps, use at least a 100amp capable lipo.
