What is everyone using to monitor there temps in the vehicle and on the charger. I have a duratrax flashpoint would that work and what would have to set it at.
I use the same temp. gauge and I havent had any problems. I use 77E for everything but note that the batteries will be slightly higher than what the guage says unless you are running nimhs.
Use any one of these for temp reading, I’ve never mounted in anything, I just bring the truck in and point the beam at what I want read, Battery, esc & motor one temp gun does it all..
I actually use the FlashPoint myself, but have been checking out the Raytek for a while now.
Just checked the E setting on mine and it was set for the default 95E.
I brought up the manual and it says 77E for Anodized Aluminum.
Does that mean that all of the motor temperature readings I have been taking for batteries are pretty accurate, but the motor and ESC temps I've been reading at 95E have been lower than what the reading has been saying?
“Everyone has a right to be stupid; some people just abuse the privilege.”
I have the flashpoint. At high temperatures the default setting is very inaccurate for aluminum. My smooth can feigao would read 90F on the can while about 150-160 right where the wires came out. I also measured the temps of my aluminum pots that contained boiling water and the outsides read about 95F. Other than that, the readings are very accurate for nonshiny surfaces.
