johnrobholmes
johnrobholmes's Avatar
08.02.2008, 10:21 AM
Yep, the timing is variable on Castle's ESCs. You set the range it stays in, and it automatically adjusts timing based on load and RPM of the motor.
---JRH---
lutach
lutach's Avatar
08.02.2008, 12:11 PM
Originally Posted by Sammus View Post
I thought I read somewhere thats how sensorless BL esc's worked (castles in particular) - that the timing varies with the RPM. I also read (in the drivers ed guide maybe? cant remember) that the esc detects the optimum value for the timing, and the timing adjustment just varies it within that optimal range. Does this sound right?
That's what I was about to ask Patrick. I got timing set at high right now and I'll see what happens when I try it out on Monday.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
08.02.2008, 07:42 PM
Ahh, I see....and knowing is half the battle!
mamba monster combos
lind5
Talking mamba monster combos - 08.03.2008, 07:12 AM
hi i was wondering about the monster 2200 combo i have seen it on back order with certain shops saying delivery will start the week comencing 25 august but i cant find anything about the combo date on castle web sight
can you tell me if this would be correct or is this shop just teasing me
lutach
lutach's Avatar
08.03.2008, 09:49 AM
Please look here: http://www.rc-monster.com/forum/showthread.php?t=13919.
lutach
lutach's Avatar
08.03.2008, 05:52 PM
Patrick,
Just came back from running the Recoil. I changed the timing from normal to high and it still heats up pretty good. I'm going to try the smallest pinion I can fit in the car and see if temps go down. Motor wasn't as hot as it was with normal timing though.
lutach
lutach's Avatar
08.07.2008, 11:37 PM
Here is a data I got from running the Recoil at the track.
The MM still heats up even though max AMP spikes are in the high 50's. I even installed a 16T pinion in place of the 19T that was in the car before with the 60A controller. Patrick, what is the max RPM the MM can go with a 6 pole motor?
tc3_racer_001
tc3_racer_001's Avatar
08.08.2008, 04:37 AM
wow. i managed to take out 150A spikes with the Mamba max and it wasnt even warm!! lets hope you can get this sorted :)
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
lutach
lutach's Avatar
08.08.2008, 10:12 AM
That's why I can't understand why the MM is heating up like this.
crazyjr
crazyjr's Avatar
08.09.2008, 04:29 AM
That is strange, it heating up on an average of 3.05 amps. I know the peaks are higher, Just thinking the average would be the culprit. Before the update that allowed us to run Neu motors on mamba's, I seen cog spikes of 120amps on a mamba 25 (on 3s lipo) and it would get warm, but not what i would say was hot. For those that think its too early to do math (saturday as well) that was 1000+watts through the little mamba, tough little buggers
lutach
lutach's Avatar
08.09.2008, 11:30 AM
There were a few guys at the track who are racers and couldn't understand why it was getting that hot. I'll wait for Patrick to give an answer of what is the max RPM for a 6 pole motor.
Pdelcast
Pdelcast's Avatar
08.11.2008, 12:55 AM
It's not the max RPM (commutation limit) that is at issue here. It's the fact that the recirculation currents are continuing (probably) almost all the time -- this is VERY hard on the ESC, as all the body diodes on all the FETs will be conducting for a significant amount of time.
Again, I would be surprised if you can ever get a 6 pole 9200Kv motor working well. That's just not a good idea.
We tested some of the CC Neu motors to destruction the other day, and the MMM had no issues running a 4 pole motor at 150,000 RPM. So commutation frequency maximum isn't the issue here.
Have you tried it with low timing? That might help reduce the recirculation currents somewhat.
But I still don't think a 9200Kv 6 pole is a good idea. 2 pole is pushing it with a 36mm motor and 9200Kv...
Patrick del Castillo
President, Principle Engineer
Sammus
Sammus's Avatar
08.11.2008, 01:15 AM
Sweet, I was planning to aim for that kind of RPM too
On a serious note though, how'd you test that? At a guess you either had a custom super HV version of the MMM, or did a super high Kv custom wind to test with?
Pdelcast
Pdelcast's Avatar
08.11.2008, 01:38 AM
Well, we only hit 150,000 on one of the 2600 Kv (1512) motors, at 56V.
It was an HV.
08.11.2008, 01:40 AM
It was an HV.
Ok, just to clear one thing up, the 2 initial motors to be offered are a 1512 2600kv and a 1515 2200kv???
Thanks Mr. Patrick....
