hi i was wondering about the monster 2200 combo i have seen it on back order with certain shops saying delivery will start the week comencing 25 august but i cant find anything about the combo date on castle web sight
can you tell me if this would be correct or is this shop just teasing me
Just came back from running the Recoil. I changed the timing from normal to high and it still heats up pretty good. I'm going to try the smallest pinion I can fit in the car and see if temps go down. Motor wasn't as hot as it was with normal timing though.
Here is a data I got from running the Recoil at the track.
The MM still heats up even though max AMP spikes are in the high 50's. I even installed a 16T pinion in place of the 19T that was in the car before with the 60A controller. Patrick, what is the max RPM the MM can go with a 6 pole motor?
