What do you think????!!!!!
willett
willett
What do you think????!!!!! - 08.06.2008, 04:55 AM
Hi guys,
I want an opinion about this motor to convert my e-maxx in brushless:
Motor Brushless 43/11 55A x Raptor E550 - E620 SE
Alimentazione: 5-6S Li-Po
Numero giro/minuto volt(rpm/volt): 1050Rpm/V
Assorbimento ampere continuo: 3-55A Min/Max
Assorbimento spunto max: 75A/5s
Resistenza interna: 19,6 ohm
Dimensioni: 43X62
Diametro albero: 5mm.
Peso: 280g.
it's used usually for the elicopter and it has a lot of torque I heard.
I'm thinking to use as a spur 40 and pinion 22 or 25
but my doubt is: is the motor robust enought to run with stock e-maxx?
Please help me.
Willett
08.06.2008, 10:43 AM
It would work for a direct drive motor (in place of the spur and slipper, bolted into the tranny) probably.
I think you need to stick to something much simpler and less experimental, such as a nice inrunner motor; 9XL on 4s lipo with Mambamax for example...
willett
willett
08.07.2008, 03:42 AM
OK Suicideneil, thanks for the suggestion.
