MMM fan?
ilpufxit
ilpufxit's Avatar
MMM fan? - 08.25.2008, 11:02 AM
My V2 MMM has been running great except that the fan quit on it's first run. So, my question is, should I fix the fan myself or take the unit out of service and send it in? I raced yesterday and I was seeing 165's on the ESC w/o fan. Maybe there's a third option where CC sends out a new fan assembly???
08.25.2008, 11:12 AM
If you contact them they can sent you new fans on their own once you check what is actually broken.
I take it fan no longer runs at startup when "cold"
Edumakated
08.25.2008, 01:04 PM
I just took the fan out all together and replaced it with a Novak 30mm fan powered off the receiver. I cut the grill out of the top of the ESC case and I no longer have problems with the fan breaking.
Warranty?
ilpufxit
ilpufxit's Avatar
Warranty? - 08.25.2008, 04:29 PM
That's what I was thinking but what about my warranty?
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
09.21.2008, 06:09 AM
Anyone know? Wanting to cut my grill out aswell but what about warranty?
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
macr0w
macr0w's Avatar
09.21.2008, 10:39 AM
The guys at Castle told me once that unless you do some soldering on the board your warranty will be intact. Modifications to the case should not void the warranty.
Don't take my word for it though.
I have modified every MMM I've had. But the mods I have done are just to use an aftermarket fan wired to the receiver and to cut out the grill on top. I also drill a few holes in the case around the caps for ventilation.
auto2
09.21.2008, 10:48 AM
just put a fan on top of it. simple works.
DRIFT_BUGGY
09.21.2008, 06:05 PM
Yeah simple, but looks like crap and makes the ESC even taller
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
