KB 45 XL got a competitor ?
Mister-T
KB 45 XL got a competitor ? - 09.15.2008, 07:27 PM
I just found this, this guy is already selling some OEM Hobbywing ESC and feigao Motors
http://cbracingshop.com/catalog/prod...7c8f2c965f8996
"We'll never have a ROAR legal motor. They're all copies of Novak's design. We're not willing to copy what we consider to be an inferior motor"
- Joe Ford - my new hero
Takedown
WARNING: May become violent.
Takedown's Avatar
09.15.2008, 09:18 PM
Kinda expensive aint it? Reminds me of the velineon because of the hex screws.
RIP- Tammy (9/14/08)
MetalMan
MetalMan's Avatar
09.16.2008, 01:13 AM
It is quite expensive, but would be a nice option. For many it's nice that it has a standard 540 mounting pattern, but I don't like that. I prefer the 30mm spacing and 4mm bolts that the KB-45 uses. The screws holding the endbells on are a nice touch, though.
Mister-T
09.16.2008, 04:07 AM
A legal BL motor for 1/10 scale racing is sold around 100 € these days... so it's no that expensive. Everthing sold in France take 19,6 % of TAX
rootar
rootar's Avatar
09.16.2008, 11:16 AM
maybe it will run cooler having so much more torque than just a standard XL, so who is gonna order one and test it out?
it is a hoss of a motor at 45mm diameter smooth can and XL length, and at 550 grams it out weighs all of the other motors we are using.
i bet it would run good, prolly wouldnt get great runtime but you never know.
rootar
rootar's Avatar
09.16.2008, 12:53 PM
i wonder who that is? because he also sells RC-monster stuff
09.16.2008, 12:56 PM
Christophe Boulet
N. 1 allée Marguerite Givernis
Résidence le Saint James Bât. A Apt. 35
34080 Montpellier - France -
bruce750i
bruce750i's Avatar
09.16.2008, 01:03 PM
I think it said it has a 5mm shaft. At the bottom of the page, the pinion teeth are called dents. Thats different. I think thats close to $160.00
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
09.16.2008, 01:08 PM
6 pole motor too. Hmm.
killajb
killajb's Avatar
09.16.2008, 02:09 PM
Interesting find. I wonder if another vendor carries this motor. I'm not sure if this correlation can be applied, but running a mamba 280-sized motor in my mini-inferno was nothing but a heat pump. I switched to a 400-sized can with tons more torque and about half the kv value and got way better performance and reliability.
Mister-T
09.16.2008, 03:59 PM
Hu, it 's a 6 turn motor where did you read 6 pole ?
bruce750i
bruce750i's Avatar
09.16.2008, 04:28 PM
Excuse my French but,
Caractéristiques :
2150 Kv
Bobinage 6 tours
Max 120A
Plus de 2000 Watts maxi
Voltage max recommandé : 25V
Diamètre : 45 mm
Longueur : 76 mm
Poids : 550 grammes
Entre axe trous de fixation : 25 mm standard 540
Format équivalent à un Speed 700 en taille
Axe moteur 5 mm avec méplat
Rotor néodyme diamètre 24 mm
Cage démontable
Roulements énormes gros diamètre ultra résistants
Câblés d'origine avec des prises PK 6 mm mâles
It's all there in plain French? 6 pole??
killajb
killajb's Avatar
09.16.2008, 04:40 PM
Just looked up some comments on Feigao's 580 motor.. Doesn't seem suitable for car use according to some. Check it:
http://forums.radiocontrolzone.com/s...d.php?t=234845
Mister-T
09.16.2008, 04:41 PM
Caractéristiques :
2150 Kv
Bobinage 6 tours
Max 120A
Diamètre : 45 mm
Longueur : 76 mm
Poids : 550 grammes
Cage démontable
2150 Kv
6 turns winding
Max 120 Amps
Power 2000 watts maximum
adivsed Voltage : 25 volts (it will turn fast with such voltage ...)
Diameter : 45 mm
Lenght : 76 mm
Weight : 550 grammes
Space between mounting holes : 25 mm standard 540 size
Equivalent to Speed 700 i term of size (Speed XXX it a reference to old brushed motor used in RC Aircraft)
5 mm output shaft with plane
Neodymium Rotor with 24 mm diameter
Dismountable housing /casing / stator
Oversized ball bearing for long life
Default wiring with Banana plug (PK) size 6 mm
jayjay283
jayjay283's Avatar
09.16.2008, 05:04 PM
what does "very free wheeling" mean ? good for a tekno clutch system ?
