stum
09.07.2008, 05:22 PM
What Neu are you running and what motor mount is that? I see you are using motor brakes as well? What do you think of the setup and what velocity are your oils.
Thanks!
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
09.07.2008, 08:38 PM
Nice action shots. You should race towing the trailer so it is fair for the nitros.
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
09.08.2008, 01:59 AM
Yeah was thinking of taking it took the track. Took it for speed runs out the front in the street and as soon as the trailer got a little sideways in would spin me around
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
DRIFT_BUGGY
09.08.2008, 02:01 AM
Thanks!
1512 2.5D (2050KV) - Yes using motor brakes. Have the MMM set at 50% brakes with no drag brake (that is plenty of brakes) Oils? As in the diff? Currently 5/10/2
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
DRIFT_BUGGY
09.11.2008, 12:22 AM
Well took it down to the track today. I changed the front shocks to a #55 piston. It was a very humid day, I was sweating pretty bad at the track. Motor temps were between 150F - 163F and the ESC & Battery was 112F. Not many pics this time. 1st picture is just my son watching me fly around the track making sure the buggy is running right (soon to be pit crew). I took the video camera down aswell but went to record and realised that the battery was flat.
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
kevin23
09.15.2008, 08:41 PM
what gearing are you running now?
I have the same setup geared 13-48 and my motor runs about 170-180 after 15 minutes.
and my 4s 5000 pack hit voltage cut right at 15 minutes.I'm thinking it's undergeared.
with the same setup on 5s temps are the same but runtime is about 20 minutes
DRIFT_BUGGY
09.16.2008, 12:58 AM
Yeah, my temps went down after going lower gearing, changing the timing on the ESC to 0 and putting thicker diff fluid in.
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
kevin23
09.16.2008, 10:16 AM
so what gearing are you currently running?
DRIFT_BUGGY
09.16.2008, 06:23 PM
13T/46T - I was first running 14T/46T which was also before I changed the diff fluids and timing and the motor was running 160F - 175F but the ESC and Battery were cool which usually means the motor is undergeared so I went up to a 15T and temps didn't really change (I think it got hotter quicker). So asked around and changed my diff fluids from 3-5-2 to 5-10-3 and timing for D wind motors is mean't to be 0 not 15 or whatever the standard timing is on the Mamba ESC. I also changed the pinion to a 13T and temps went right down. I haven'y tried the 14T or 15T pinion again as even on 13T (42mph ish) it is still fast
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
kevin23
09.16.2008, 08:19 PM
thanks,what I needed.
I have been running 13-48 on 5s,this weekend I tried 4s with same gearing and was slower on straight,but runtime went down and motor temps stayed the same
abiye
09.17.2008, 10:05 AM
good info
DRIFT_BUGGY
09.19.2008, 03:22 PM
Well had to happen sooner or later. Playing around in the backyard, came in to check the temps and notice the fan not working. Had a good look in and saw that 3 of the blades on the fan had snapped off. MMM still runs though and I have a spare Novak fan sitting in the cupboard. Just got to decide what to do - Send it back to CC or just put the Novak fan in
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
kevin23
09.19.2008, 09:57 PM
that sucks,my mmm broke the fan plug off of the board already.
DRIFT_BUGGY
09.20.2008, 06:23 AM
Took the cover off tonight and removed the blades. Fan still works and MMM still work fine. Thinking about trying the MMM without the ext. bec and see what happens
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
stum
09.21.2008, 01:28 AM
Just finished up my e-8ight using the tekno conversion.. WOW awesome! I've got the MM esc w/ fan and ccBEC (4s config). Gearing is stock spur (48) and 16t on the e-clutch. No temp issues and she runs great! Motor is the Medusa v2 2000kv 60mm.
7,10,3 for diff fluids
50wt w/ Green on front shocks
35wt w/ Black on rear shocks
She runs great and I was owning the nitro's today!
