v2 on 6cell lipo who still alive??
e-mike
e-mike's Avatar
v2 on 6cell lipo who still alive?? - 09.25.2008, 06:45 PM
i know that a lot of thread was made on the mmmv2 but i just want to find the guy's who run the v2 on 6 lipo cell or the equivalent on life-po (with the internal bec) and still running stong!!!!!
for me i never pass over 25min on 6s
D8t on juice!!
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
09.25.2008, 07:42 PM
Mine is fine but I have the red wire pulled and I am using an external bec. I killed two before this though with out the external bec.
erevo15151y
09.26.2008, 10:20 AM
ive had two v2's go bad on 2 x 3s 5000hv maxamps,using internal bec, getting another this week ill let ya know how it goes,....
JerryF504
I don't understand, but I don't think I like it.
JerryF504's Avatar
09.26.2008, 10:32 AM
I have a v2 that runs fine on 2 Maxamps 3s 5000mah in series using the internal bec and I also have a v1 but I'm using an external bec on it.
e-mike
e-mike's Avatar
09.26.2008, 04:28 PM
Originally Posted by JerryF504 View Post
I have a v2 that runs fine on 2 Maxamps 3s 5000mah in series using the internal bec.
your the only onei try my third one unit yesterday with the internal bec...no issue but i was to scared to see my e-revo stop in the middle of my run....however i installed a ext. bec just to be sure....work great so far....close to 3 hour on it!!!!!
D8t on juice!!
SunnyHouTX
SunnyHouTX's Avatar
09.26.2008, 04:59 PM
I've got one running two 3S TP 2500mAH lipos in my Rustler. Don't have much runtime on it due to lack of time to test. Will know more tomorrow.
bruce750i
bruce750i's Avatar
09.26.2008, 05:19 PM
That should be interesting a 6s MMM rustler. Just a v1 on 6s for me.
09.26.2008, 05:32 PM
Note: MMM failures are not related to input voltage; they can die just as easily on 4s as they can 6s. Until the exact cause of failures is determined, assuming the voltage being used is too high is just plain daft....
e-mike
e-mike's Avatar
09.26.2008, 05:42 PM
are sure????i dont really unterstand why some failed and not...each esc had the same built....and same part....
D8t on juice!!
killajb
killajb's Avatar
09.27.2008, 04:14 AM
I've been running mine (V2) in stock form on 6s for 3 weeks now with no issues.
gixxer
gixxer's Avatar
09.27.2008, 05:07 AM
v1 6s with a neu 3d, still running strong.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
09.27.2008, 07:02 AM
All 1:1 cars have the same build too, why do some go 300,000miles and some go 50,000? There are bound to be failures on everything. example anything that is cast could get an air bubble in it and wouldn't be detected on the outside, but when it fails you'd know, and the one right before and right after could be perfectly fine. Anything on this planet can fail at anytime for any reason - that's life and the sooner you come to realize and except that the sooner you will be able to enjoy life. Some MMM die at start up, some die after a few seconds, some after a few minutes, and some after a few hours. There's really no way of knowing, just know that if it does CC will take care of it!
e-mike
e-mike's Avatar
09.27.2008, 10:43 AM
nothing more to sayyour right
D8t on juice!!
TexasSP
Something, anything, nothing
TexasSP's Avatar
09.27.2008, 10:47 AM
Had mine on 6c Flightpower with a 2.5d since I bought it. All has been well.
www.cubicle101.com
Sammus
Sammus's Avatar
09.27.2008, 11:32 AM
got two here run on 6s lipo and 7s a123 running box stock, probably an hour or so or more on each and no sign of trouble yet.
