Yup, I am not sure If I got my diff ratios right but I am going to try this setup:
Differential Ratio: 4.09
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 11
Total Voltage: 18.5
Motor KV: 2900
Tire Diameter (inches): 5.8
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.003
Spur/Pinion Ratio: 4.18 : 1
Total Ratio: 17.10364 : 1
Tire Circumference (inches): 18.22 inches (462.82 mm)
Total Motor Speed: 53650 RPM
Vehicle Speed: 54.12 mph (86.94 km/h)
Estimated Adjusted Speed: 50 mph (81 km/h) - 7% loss
Effective KV Value: 2900
KT constant: 0.47 oz-in/A
MGM Compro 160 amp, 18 cell brushless car controller
1521/1D 2,900 16.93 3.3 0.003 5.5 60K 1,750 watts 3,500 watts 21 volts
