Inside Neu Motor
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
Question Inside Neu Motor - 10.28.2008, 03:36 AM
I took apart my Neu 1512 Motor today and when I removed the end bell there was two gold spacers sitting on the shaft (1 short one and 1 long one) Does it matter which order these two spacers go on the shaft?
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
othello
HV basher
10.28.2008, 05:04 AM
When i changed the bearings on my Neu 1512 i also had one longer and one shorter spacer. As i drove my motor in wet conditions i had some marks on my motor shafts.
With mine: the longer spacer is used between the rear bearing and rotor. And the shorter one goes on the opposite side.
DRIFT_BUGGY
10.28.2008, 05:13 AM
My short one is probably 1/3 the size of that one showen.
What are those connectors you using?
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
othello
HV basher
10.28.2008, 06:00 AM
Those are kontronik silver plugs soldered on the motor wires (comes with the kontronik line of ESC). It's a Neu 1512/2Y (1400kv) which i use with 8-10s A123 ... low amp draw.
tc3_racer_001
tc3_racer_001's Avatar
10.29.2008, 04:27 AM
stupiud questions.
1. how do you take them apart? unscrew the screws then what?
2. are we allowed to open them up and clean them out or is that voiding the warranty?
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
DRIFT_BUGGY
10.29.2008, 06:35 AM
1) unscrew the screws and then tap the shaft (front of motor) on ground and it will pop out
2) not sure
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
tc3_racer_001
10.29.2008, 05:32 PM
thanks.
hyper 8.5 pro SOLD!
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
