How Do You Replace Ultra Shocks (EMaxx Stock Shocks) Shafts?
rawfuls
roofles.
rawfuls's Avatar
How Do You Replace Ultra Shocks (EMaxx Stock Shocks) Shafts? - 11.08.2008, 12:48 AM
I can't seem to find a way, I'm just uberly retarded...
Help... anyone?
Can't find it in the exploded diagrammys.
P.S. I like these shocks with my Trinity XXX springs, so no upgrade.. yet
rawfuls
roofles.
rawfuls's Avatar
How Do You Replace Ultra Shocks (EMaxx Stock Shocks) Shafts? - 11.08.2008, 12:49 AM
Help... anyone?
11.08.2008, 12:53 AM
Take the cap off and the plastic end off the shaft and push it through the body...
Reverse for assembly.
rawfuls
roofles.
rawfuls's Avatar
11.08.2008, 01:09 AM
The shaft is bent =/
And how do I remove the rod end?
11.08.2008, 01:13 AM
Hold the shaft with pliers and unscrew the rod end.
rawfuls
roofles.
rawfuls's Avatar
11.08.2008, 02:11 AM
As far as the bent shaft, should I attempt to cut it with some cutters?
11.08.2008, 02:45 AM
I would try to straighten it out and oull it out the top. If not then cut it off and try to keep the cut clean so as not to destroy the o rings in the bottom of the shock.
rawfuls
roofles.
rawfuls's Avatar
11.08.2008, 02:48 AM
Alright, thanks!
Looking forward to rebuilding the maxx later tomorrow -.- 10:48, can't function!! >_<
wallot
wallot's Avatar
11.08.2008, 02:53 AM
remove the shock cap.
remove the shock end
slide the shaft with piston up from the shock body.
remove two E-clips holding the piston and you got just the shaft
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
Rnemhrd
Rnemhrd's Avatar
11.08.2008, 11:49 AM
http://www.traxxas.com/PDF-Library/3905_front.pdf Exploded view. http://www.traxxas.com/support/kb_se...cat=165&id=518 Traxxas manuals.
rawfuls
roofles.
rawfuls's Avatar
11.08.2008, 10:11 PM
Thanks a ton for that diagram Rnemhrd!
I took it apart in the sink, and remembered that in the diagram (took a close look before taking it apart) that there was small parts, and in the middle of taking it apart, I shut the drain, and that was when the small tiny eclip fell off... Whew!
Got it working, hopefully 40WT w/ Trinity XXX Hard Springs should do it. Hate bottoming out!
Rnemhrd
Rnemhrd's Avatar
11.09.2008, 12:38 PM
I would save up some cash and upgrade the shocks. Use the forum search to see what the guys are using, what not to use, and how they perform.
rawfuls
roofles.
rawfuls's Avatar
11.09.2008, 12:51 PM
I'm gonna get some 1/8 XTM or UE or Ofna shocks when I get some extra cash.
Until then, the shocks right now are just fine for my appliance.
