i am starting with 5/10/5 in the diffs
with 4s and a 1512 2.5d i am thinking about a 17-19 t pinion , the rc8 has a 44t spur and truggy diffs
for tires i have been thinking of the proline revolver wides or aka tires (either)
for now i will run the ft shocks , with some mods , rtr caps and bladders that are cut out , and about 5mm of fuel line inside on the shafts and start with 40 wt
i cut the esc. top mount plate , the part where the esc. mounts is about half the size now , i decided to try and mount that novak motor with a 12t and it was way off
pics will come once i get a body painted , motor, and i get Mikes chassis
.......no sense in wasting thread space , it will be a few weeks though
i will hopefully have some vid. of a race coming up on the 6th of Dec. , there are a few of us here that are going to go and hopefully have enough to have a electric buggy class , i will run it as is if i need to , really dont want to let any of the guys up here down , even if it goes up in flames.........the motor is a 4.5 hvmaxx motor and runs hot and the fan on the esc. runs alot as well
ill check out that tire thread , thanks
