TDC57
TDC57's Avatar
11.30.2008, 03:01 AM
WOOOT, WOOOOT, WOOOOOOTT!!!
She ALIVE!!!! YES!!!!
Congratulation SIR..
Now about your gearing (!!)
You are using the same gearing I use on my buggy , Jordan, gear the bad boy!..
I'm running 24t & 52 spur. No heat issues at all on 6 & 8s (try this setup sir)
I'm stocked for you Jordan, it looks great too…
Great job all the way around..
Have a great weekend Sr..
Shaun.
P.S.
The last time i sent my controller to MGM it took 15 weeks.. Just and FYI..
Nothing!.. Hahahahaaa..
jordan...
one.five.two.seven
11.30.2008, 07:49 AM
Wow, this discussion came alive while i was sleeping , I've decided to run the MMM, i got the gears today and am going to get grinding tomorrow to refit the CD with the bigger spurs, so hopefully not to long before she's up and running again. After all the testing Lutach did with his ESC's it wont hurt for me to be the guinea pig with the MMM/152x motors.
@Shaun: you said you're running 52/24, is that on your G3R? What is your final drive ratio? Going on your gearing, the spur/pinion ratio is 2.167. With my previous/explosive gearing (42/16) its 2.625, so really you could say im geared lower. But with the reduction in the e-maxx tranny im pretty sure yours would come out as the correct ratio. If i could get your final drive ratio from Brian's calc i could work out an equivalent gearing on my truck.
@Jerry and Shaun: it could well take 15 weeks, but im just going off what Martin Dvorsky replied to me in his e-mail, he said once he gets it it should take a day or two to get repaired as it was an easy fix, hard to believe i know, but at least i'm trying to stay optimistic
thanks guys
jordan
Maybe???
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Maybe??? - 11.30.2008, 07:56 AM
Just maybe MGM is trying to get a little better in dealing with its Anerican and Ausi customers in order to improve customer relations. You have to admit from all of the info posted up on here that ten to 16 weeks is a bit rediculous??? We to hope that yours comes back quicker Jordan.
jordan...
one.five.two.seven
11.30.2008, 08:04 AM
lol thanks Jerry, Im really impressed with their customer service so far after all the bad press ive heard on here. I e-mailed Martin and got a response within three hours thats from the other side of the world. Hopefully the repairs go as smoothly as my conversations via e-mail with him.
TDC57
TDC57's Avatar
11.30.2008, 08:30 AM
Originally Posted by jordan... View Post
Wow, this discussion came alive while i was sleeping I've decided to run the MMM, i got the gears today and am going to get grinding tomorrow to refit the CD with the bigger spurs, so hopefully not to long before she's up and running again. After all the testing Lutach did with his ESC's it wont hurt for me to be the guinea pig with the MMM/152x motors.
thanks guys
jordan
Ok..
Your running the new V3 MMM right (??)
And your using what 6 or 8 s ??? (don’t even attempt) 10s Jordan unless your doing Brian G mod and then some..
As for my final drive ratio (It’s late I'm going to bed) I’ll get back to you tomorrow on that. It’s truggy diffs, single speed trans (Traxxas gears) on 6 -8s with a Neu 1515 3D S (polished) don’t forget that.. LOL.LOL.. and I can run the lipo’s down and still have no heat issues with 24 / 52… I can send you the gears if you want to try them out ?? Let me know it’s no big deal..
Yes stay optimistic.. Life is always better there..
P.S.
Are you 100% yet ???
jordan...
one.five.two.seven
11.30.2008, 08:44 AM
Yep, i just got a MMM V3 last week. Im running 5s, same as in the vid, im not THAT crazy . My MGM is limited upto 6s anyway. No worries on the ratio, ill work it out now, just didn't know which diffs you were running (RCM buggy or truggy ) Gotta remember the gmaxx single speed ratio is 1.7777, but with the CD its 1:1, i've also got buggy ratio diffs, so the spur/pinion will be kinda weird. No need for the gears, i don't think they'd fit between the frame rails, ive got a 48/10 combo to try out. I'll crunch some numbers right now, but i think theres something wrong with Brians calc, theres a Neu 1515/3D, but no Neu 1515/3D (polished) option .
The necks real good now, im back to running, riding, gyming again. I just got cleared to get back into all this stuff a week ago, also back at work which is good, i need more money for RC Unfortunately i cant get back into a race car for another 3 months, need to wait for the muscles/nerves to regenerate, (they take alot longer than bone.) So hopefully by March everything is all good.
have a good sleep
EDIT: thanks to BrianG's calc, heres what i got...
Shauns final drive ratio: 16.04537:1
My 42/16 final drive ratio: 8.68269:1
My 48/10 final drive ratio: 15.87692:1
My 46/12 final drive ratio: 12.67949:1
Now i know why my MGM burnt...
TDC57
TDC57's Avatar
12.03.2008, 04:06 AM
Jordan I laughed my but off when I read that!!
Thanks for the smile and small hernia..
P.S.
I'm GLAD to hear about your neck!.. WAY COOL..
jordan...
one.five.two.seven
12.03.2008, 07:49 AM
Time for some updates i think!!!
I got my gears from Amain, ordered Tuesday, arrived Friday, cant get much better than that!! So i went about modding my CD mount and my frame rails to fit with the larger 48t spur gear. I cut a slot into the bottom diff plate for clearence, and also notched out the frame rails. I also went about direct soldering my motor to the MMM wires. I had to make some small extensions to get them to reach. I think the MMM install went great and im happy with how clean it looks. Here are some pics...
Down for maintanence
slotted and notched parts
wire extensions and motor with wires directly soldered
Some pics ready to run!!
Read on to see the truck with the MMM ran...
jordan...
one.five.two.seven
12.03.2008, 07:58 AM
... so i took it out for a run this evening.
WOW is all i can say With the lower gearing this thing came alive. Still no wheelies, but SO much power, and all of it useable. Handled awesome as before. Mostly kept all four wheels planted round quick corners and pulled some nice 4 wheel drifts. The MMM ran excellent!!! It was really smooth on startup, no cogging at all, the brakes were perfect and it really delivered the power smoothly through the whole throttle curve. So happy with its performance, my temps after about 15-20mins were
motor 110-120F
ESC 120-130F
batts 80-90F
The fan only came a couple of times, but after i let the truck sit for around 10 seconds it went off and was ready to go again. I'd like to say that the MMM really can handle any motor thrown at it, great job Castle!!!
Heres a vid:
Now for the aftermath, can you spot whats wrong with this pic
The pillowballs screwed out, which made the driveshaft pop out of the cup, and under some hard breaking, sheared the pin
My question is, is there an easy fix for this problem? Can i get the pin out somehow, i was thinking about drilling it out, and then put a drill bit or allen key in. Much like the roll pin mod people do in the 3906 tranny's. Any suggestions, i cant wait to run this thing again!!!
hope you liked the updates
jordan
Press.
JERRY2KONE
JERRY2KONE's Avatar
Press. - 12.03.2008, 08:10 AM
The pins are surely put in with a hydraulic press, so you should be able to press it out if you have access to a press. Then press a new pin back in. Yes a drill bit or allen key should hold up just fine. Nice work on the vehicle, and it looks to run pretty well with the MMM. How much does that thing weigh loaded up? It looks to be kind of heavy in the Video. Just curious. Looks like you have a new bouncing baby boy on your hands. Way to go Jordan.
jordan...
one.five.two.seven
12.03.2008, 08:20 AM
i have got a mate whos a mechanic, so i should have easy access to a hydraulic press. It is a bit of a beast, 14lbs all loaded up. It sure did run well with the MMM V3, time will be the test now i guess, hopefully it doesn't crap out on me after a couple of weeks.
Not Too Bad.
JERRY2KONE
JERRY2KONE's Avatar
Not Too Bad. - 12.03.2008, 09:05 AM
Well considering what you have in there, that is not too bad for weight. Half of that is probably batteries, and motor. All you can hope for is that it holds up until your MGM is returned from the factory. I would have some fun, but nurse it a little bit until you get close to having the MGM back, then run the hell out of the MMM. Then you will have a good comparison going between the two. You can also order those driveshaft pins either from UE, or RCAlloys. I am not sure if Mike has them or not here on RCM. It would not hurt to have a few spares on hand for future issues.
lutach
lutach's Avatar
12.03.2008, 10:36 AM
Want more usable power, lock your center diff or go with what I use in my 1/8 scales, the Ofna solid center. I was having similar issues with my 14lbs (Maybe more when I use 5S2P TP Extreme the long ones lol) as it would just unload all the power to the front wheels. I tried different diff oil and went up to 100K and it would still unload. After I installed the solid center, it became just like my 4WD 1/10 scale and drives like it too, but not with the 5S2P lol. I can do wheelies anytime I feel like it. Look at this picture, it's a perfect match for the 1527
SV6000
SV6000's Avatar
12.03.2008, 08:41 PM
Hey Lutach you sure like running HV setups.
e-mike
e-mike's Avatar
12.03.2008, 08:48 PM
wowthe 1527 are really big...oufffi want one f these beast for testing the v3
D8t on juice!!
