1/8 Diff Oils
Steve182
Steve182's Avatar
1/8 Diff Oils - 11.30.2008, 03:19 PM
What are you guys running in your diffs for oils ? I will be running a Hyper 7 w/ a Feigao 10xl, 6s a123, and MMM. I will mainly be bashing, but will run on the track once in a while too.
| Hyper 8 Pro- MMM, Castle 2200kv / Zippy 4s 5000mah
| Jammin CRT- MMM, Feigao 10XL, 5s Zippy 5000mah
| Savage Flux- Castle 2200kv Combo, 6s Zippy 4000mah
  Send a message via AIM to Steve182
11.30.2008, 03:48 PM
Not exactly typical, but I run 3k in rear, 5k in the front, and 50k in the center (to tame front tire ballooning), but this is more of a track setup.
In my MBX5r (CORR conversion), I run 5k in rear, 7k in front, and 100k in center. This is more of my basher vehicle. Turning doesn't seem to be adversely affected too much and the center really helps reduce ballooning in the front.
Semi Pro
Semi Pro's Avatar
11.30.2008, 03:59 PM
i run 5k front 7k center 3k rear
rschoi_75
Certified Spaceball
rschoi_75's Avatar
11.30.2008, 04:27 PM
5K Front, 50K center, & 3K rear for both my buggy & truggy.
rcm xt8
rcm xb8
rcm crt.5
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
11.30.2008, 06:07 PM
5KR, 10KC, 5KF but I only backyard bash at the moment and I am not going to go out my way to buy diff oils. I may try 30k in the center, though 10k is fine most of the time.
Area 52 Ranch Raceway
T.R.C.R.
spaz163
Functionality with a dash of Form
spaz163's Avatar
11.30.2008, 06:17 PM
5k in front, 120k in center and 3k in the rear.
Definitely go with heavy center fluid, my 8XL was running very hot while running 10k in the center!! Front end was unloading terribly
MetalMan
MetalMan's Avatar
11.30.2008, 06:41 PM
7k front, 30k center, 5k rear
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
12.01.2008, 06:18 AM
Im currently running 5K 10K 3K but thinking of trying out 15K in the centre
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
Unsullied_Spy
Unsullied_Spy's Avatar
12.01.2008, 06:43 AM
For bashing I run 30k in the center diff, and grease the front and rear diffs. Works well enough for me and it's cheaper than buying more oil.
drkros3
12.01.2008, 01:21 PM
i run 5k front 5k center 2k rear.
DickyT
12.01.2008, 02:00 PM
7k front, 100k center, 5k rear
Steve182
Steve182's Avatar
12.02.2008, 12:39 PM
Wow thanks for all the replies everyone. Seems like everyone uses a different setup then one another... I think it will be a more trial and error thing.
Looks like I will use something heavier in the center though.
12.02.2008, 12:43 PM
Generally, BL power has so much torque that it's easy to unload the front and balloon those front tires. Not to mention that power is then wasted going to nothing.
If racing, a looser setup is better since you aren't as concerned with raw power as driveability (and cornering), but bashing is a different story.
Steve182
Steve182's Avatar
12.04.2008, 02:24 AM
Thanks for the input again guys, I have chosen to go with this setup for starters:
7k in the front, 50k in the center, and 5k in the rear.
jhautz
jhautz's Avatar
12.04.2008, 02:58 AM
5/7/2 on the buggy
7/12/3 on the truggy
If you go too high on the center dif fluid you loose alot of off power steering on the turn in. Makes it hard to drive on the track IMO. I would rather run a more normal dif fluid weight in the center dif and controll the tire balooning with my throtle finger than give up the turning. Makes it hard to turn a fast lap if every corner you are forced to go wide cuz you dont have any off power steering. Just my opinion. If you are parking lot, or schoolyard running, then yea load up on the center diff, it makes the most of your forward traction and acceleration and more fun for really getting the most from the brushless power.
to make it...
or break it...
Silent...But Deadly
