i am trying to setup mech. brakes on my RCM RC8t and the motor can rubs up against the brake discs before the spur and pinion can engage. is there a solution to this that i am not seeing?
Jammin SCRT10 Neu 1512 1y
i thought of doing that but i would have to dremel quite a bit to make it work and already there is only 3/16" of the disc that touches the pads. if i dremeled it i would lose alot, if not all, of my stopping power.
i also considered changing to larger gears. the gearing on there is 16/50 and i would have to use probably a 17/54 or even 18/54 to get it to work and that is not gearing that i want to use.
no, you are right. if the spacer is even almost the same size as the motor can, which it looks like it is, it still wont work because then the spacer will just hit the brake disc.
