Difference between DX3R and DX3S
BL Dreamer
Difference between DX3R and DX3S - 01.10.2009, 02:05 PM
Is the telementry just added to the dx3r or is there other options that are dropped when you get the DX3S. I like the telementry concept especially for temp control but If I losing options by getting it instaed of the dx3r then I will consider. Also anyone know how accurate they are?? Thanks
FG101C
01.10.2009, 02:46 PM
I know the handle is different and it feels "cheaper".
Matthew_Armeni
Matthew_Armeni's Avatar
01.10.2009, 03:30 PM
You can't mix the aux channel with the throttle like you can with the DX3R, only mixes with the steering. Kind of a bummer for those who like to mix mechanical brakes in with their throttle.
  Send a message via AIM to Matthew_Armeni
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
01.10.2009, 03:34 PM
The DX3R uses DSM2 technology, it's faster responding than the original DSM that the DX3S. Also the R will work with both DSM1 and DSM2 rx's where the S will only work with DSM1 rx's. I had thought about selling my R to get the S cause I like the idea of knowing the temps and voltage as I'm running but since I already have a couple DSM2 rx's and they aren't compatible with the S I decided not to do it.
BL Dreamer
01.10.2009, 03:49 PM
Wow no mixing for mech brakes is huge as this was the route I was heading....plus the incompatibility with the DXm2 suxs as well. Well I am glad I asked before making the wrong choice. Thanks guys.
01.10.2009, 05:06 PM
FWIW: the DSM1 vs DSM2 isn't really noticeable unless you are really looking for every microsecond of response time. For racing, it can help (although I never noticed it), but for bashing, it's not needed IMO.
Despite the fact I have the DX3r, I'm only using one DSM2 rx, the rest of my vehicles use a regular spek rx because of price and availability locally.
The telemetry in the S would be nice, but as long as the setup is done right and temps are monitered for the first few runs to verify, a temp sensor is extra fluff. And rpm sensor is good for what? To measure speed? That's what a GPS/radar is for (and more accurate because of tire balooning). I suppose rx/system battery voltage monitor would be nice, but not sure if it has that.
Just my $0.02...
drkdgglr
01.10.2009, 05:20 PM
it does...
01.10.2009, 05:21 PM
Ok then, that would be the only reason for me to get it...
drkdgglr
01.10.2009, 05:25 PM
I have only run with the temp sensor once. But it was good to find out that motor temps were highest when I stopped running the truck. Makes sense though as at that point there's no airflow. So it might be good to do some slow driving at the end.
edit: the dx3s also has a timer. I like that about it too.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
01.10.2009, 06:00 PM
DX3R has a timer too
01.10.2009, 06:18 PM
so does the s
Daytona675
01.10.2009, 08:29 PM
What about picking up one of these and using what you need?
http://www.spektrumrc.com/Products/D...ProdID=SPM1305
01.10.2009, 10:52 PM
Not sure if it was mentioned already, but the S has a 10 model memory and the R has a 30 model memory. My fleet is getting close to exceeding the S capabilities, so it's nice to have a few extra slot available...
kulangflow
Never Fast Enough
kulangflow's Avatar
01.12.2009, 03:25 PM
That might be a +1 for the S for me. It might help force me to keep the fleet down to more manageable numbers <11, assuming I sold all the other tx I have.
01.12.2009, 05:19 PM
This was the main reason I got a M11 a while back. I actually have 30 or so fm receivers for it too. I also have 30+ vehicles. My M8 is setup for spectrum so I have been using that alot on the vehicles that do not have mech brakes. I am sure that 10 model memory is fine for most people...
Also, what are the street prices on both the 3r and 3s? I could look it up but I am lazy...
