coolhandcountry
coolhandcountry's Avatar
11.27.2005, 07:39 PM
it would be pretty quick. have great power and run time beyond your belief. The advantage the 3695 has is no rpm limit like the 36120. but you don't have to worry about that.
Peace!
Country
Help support the
Rc-Monster
Buy here
mack
mack's Avatar
11.27.2005, 08:20 PM
I don't now of anny of you are interestit but here is a site whit a very good price 179dollar for the hv-110
http://www.prop-shop.com
MetalMan
MetalMan's Avatar
11.27.2005, 08:32 PM
10s on 14XL would be awesome! Actually, it would probably be too awesome! So awesome that it would tear the truck apart!
E-Traxxer - you could experiment with this idea and tell us how it works :). I am sure we would all like to know how it would perform.
E-Traxxer
11.27.2005, 09:01 PM
I'd like to try it out.. but you say that it would tear the truck apart! .. That isn't a good thing now, is it? :P Im going to make a slipper adaptor that will handle an E-Maxx steel spur for my savage, going to get the HB cups and stronger dogbones, and I already have 23mm hexes.. what is going to break on that?! This setup would be fairly cheap (except for the lipolies, of course) at $180 for the controller, and $90 for the motor, that's only $270! Christmas will be a good day, a good day indeed! :L:
I'm going to see if it is compatable with pistol grip radios first, because my plans will go down the drain if it isn't! :eek:
MetalMan
MetalMan's Avatar
11.27.2005, 09:06 PM
Pistol grip vs. stick was a concern of mine. I think that by adjust the endpoints and setting the trim it could be figured out (of course a computer radio is needed to do fine-tuning).
By "tear the truck apart" I mean that this system could very well be capable of doing just that. Pulling full throttle from a dead stop would make it do more than just wheelie!
mack
mack's Avatar
11.27.2005, 09:09 PM
I don't now if the hv-110 will handel the setup for a car.
I had emailt them at CC but they didn't respond so I don't now
the spec's look good so?
E-Traxxer
11.27.2005, 09:28 PM
But I have a wheelie bar! :p I don't think it could tear any drivetrain component up after my fully redone drivetrain is done, there wont be a single peice of plastic in the drivetrain besides the HB cups, which are stronger and better than aluminum cups.
Mack- The specs ARE good, but it is only a plane controller. It has a possibility to handle a lower amp draw motor (such as the 14XL I'm going to use in my possible setup) on a higher voltage setup because the motor won't be pulling as many amps, so he controller will be able to cope with the smaller amp spikes.
mack
mack's Avatar
11.27.2005, 11:19 PM
So you can't put say 18 cells on the hv-110 whit 14XL
You have to co to 10s?
E-Traxxer
11.27.2005, 11:22 PM
18 cells would be fine on 14XL with that controller, but it wouldn't be too fast because the motor has a low KV rating and needs mroe voltage to operate at maximum effieciency.
mack
mack's Avatar
11.27.2005, 11:32 PM
but whit the 14XL and 10s is this not a beter controller?
3670 / MicroCar
70 Ampere
4 bis 36 Zellen
28 Gramm (ohne KK - ohne Kabel)
70x30x8 mm
Vorwärts-Rückwärts-Bremse
mit RC-Car Software
Kühlkörper
2 Elkos
Die Angabe der max. Zellen beruht auf die Berechnung mit
1,2V/Zelle
It's 230euro lets say 200dollar
E-Traxxer
11.27.2005, 11:53 PM
Hehe, that would probably be better, but it's $271 US, not $200 :P
E-Traxxer
11.28.2005, 03:45 AM
Doh! Boy am I stupid :mad: I'm not using mechanical brakes on my savage! Would a good alternative be the 3670, even though it doesn't have a heatsink (from the pics I have seen, at least)
mack
mack's Avatar
11.28.2005, 06:01 AM
$200:C: It was very late for me but i mean to say was lets say $280
Serum
Serum's Avatar
11.28.2005, 02:23 PM
why am i answering you emails mack, no offence, but i find back every question you emailed me here?
mack
mack's Avatar
11.28.2005, 02:37 PM
In this thread I was only giving E-Traxxer my thoughts
And since it was about 3 o'clock in the night I thougt I'd
have a chat whit some guys on this forum.
Offcourse I appreciate your help and the fact that you are willing to share your information with me. However there is nothing wrong with sharing thoughts on this forum right?
