LifeP04?
trev3813
Dsm needed
trev3813's Avatar
LifeP04? - 01.28.2009, 04:41 PM
Umm, care to explain? Is it A123 cells? Decent?
http://www.hobbycity.com/hobbycity/s...8&ParentCat=85
01.28.2009, 04:56 PM
Basically the same chemistry. Still heavy and require a 2p config to work adequately...
trev3813
Dsm needed
trev3813's Avatar
01.28.2009, 05:13 PM
Ah, was browsing on hobby city and saw that, Im runnin 6s lipoly, no A123
01.28.2009, 05:15 PM
A little off-topic, but does anyone know if their A123 dev kit contains all 4 cells or just one? Seems too cheap for the full dev pack, but a little expensive for one cell. The description says dev pack, which comes in a 4 pack IIRC...
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
01.28.2009, 05:23 PM
It's a single cell. There's no way they could be selling (4) A123-branded cells that cheap. I think they mean it's the same cell you get in the dev. kit.
pedeboi364
01.28.2009, 05:41 PM
ya, i was wondering the same as BrianG. A single cell is about $12-$15 at some places, and considering how much cheaper everything else on HC is... maybe someone can email them and get an explaination??
Check out my FS thread in the General Discussion!! Help me go lipoly!!!
01.28.2009, 05:55 PM
Originally Posted by pedeboi364 View Post
...A single cell is about $12-$15 at some places, and considering how much cheaper everything else on HC is...
Yeah, that's where I was coming from...
01.28.2009, 06:11 PM
*Thats what she said.*
What's_nitro?
01.28.2009, 06:16 PM
*sigh*
01.28.2009, 06:21 PM
What, you didnt expect me to pass that one up did you?
Anyway, I think the developer kit cells are more expensive as they are more like matched, hand-picked cells. Useless when you are buying them individually, but in a normal pack of 4 or whatever, it means they are more likely to stay in balance, like matched lipo cells in a pack for example...
bensf
01.28.2009, 06:47 PM
LiFePO4 aren't the same as A123. The A123 uses the same LiFePO4 chemistry, but with a few additives. IIRC.
mohanjude
Need for speed
mohanjude's Avatar
01.28.2009, 08:31 PM
You are correct. A123 which is a propriety name for the process of 'doping' the anode and cathode with chemicals that enable the cell to discharge with a higher C rating. True A123 cells IMHO are much better than the cheap chinese imitations that are floating around. I have tried both and the A123 are much better suited for the purpose of Racing and Bashing.
highflier
Emaxx- FLM wannabe
01.28.2009, 08:50 PM
those looked like true A123 cells. HC also sells knock of LiFe cells but they do not perform the same from what I have heard.
As for A123 cells they work just fine in my monster truck. They are a tad heavier but you can charge them so fast with just 2 packs you can run all day. Best way to get the cells are buy a dewalt 36 volt battery pack and havest the cells out of there. You should be able to get them for about 10.00
Highflier
E-maxx Brushless
HPI MT Racer Brushless
Associated rc10t brushless
Associated B3 Brushed
Tons of airplanes and a few Heli's
pedeboi364
01.28.2009, 08:57 PM
where can i get a dewalt pack cheap^^???
trev3813
Dsm needed
trev3813's Avatar
01.28.2009, 09:04 PM
$10? Where?!?!
