So both + and both - would be taken out of the plug and spliced back into the + and - after the switch and before the RX? I would still have a + and a -going into the RX (bat) and each servo plug would only have a signal wire.
pretty much but generally to an ubec rather than directly to the battery.
When i did this mod on my clod I removed the signal wire from the servo plug and instered it into a spare male plug - each servo then has two plugs, one with + and - and one with signal.
The signal plugs go to the rx.
For the + and - leads i created a 3 to 1 y adapter - plugging in the two servos and the ubec - the two servos are then powered directly from the ubec.
For the output of the y i left only the - which plugged into the rx to provide a common ground.
