Originally Posted by Arct1k
Magman - good stuff - going forward the instructions are being included in the kits - Let know how you like them.
I need to build mine tonight - The outercases are so amazingly light!
For kicks, I put the assembled rear diff in the bulkhead..fit like a glove....Installing the compression ring was a bit tricky, but once completed, they spin perfectly.
The only concern I have is that when I tighten the case, you have to be careful because the diff will bind if you snug the case to far....other than that, they are a great upgrade!
