Originally Posted by timaneli
i run between 10 and 30 min too... do you notice better run times with the medusa then the feigao?
what medusa should i use in a e-revo?
i was thinking the 36-60- 2000 or 2200kv one... os good choice?
Run time will depend on the amp draw of the motor, weight, gearing n batt capacity. medusa runs cooler n last longer as the magnets n bearings are much better.
I will suggest 70mm rather than 60mm as it's stronger n able to run d truck with less effort. What batts are u running for ur race? That will determine wat motor u shld use.
I used to run 2000kv in heats then main change to 1600 but I found it too tiring. So I use 1600 now throughout n change gearing.
Heats I use 16Pinion with 4s 5000 n main I use 11pinion on 6s 5000 with 1 batt change
ERevo has 2 batt it will b slower to change batt so in main u must use high capacity batt n lower d gearing so the esc n motor will run cooler unless it's winter in your county.
Make sure ur packs are of the same age as in series d older/weaker pack will discharge faster leaving it overdischarge.
Wat batts u hv now n gearing? Is this ur first race?
