just finished breaking in my LST -
12.22.2005, 10:27 PM
just finished breaking in my LST then I broke it litterly :M: any suggestions on what kind of a arms are best . what do you think of RPM a arms? Thanks for your input
The old arms(LST1) seem to have voids in the mouldings.I was told it's when they pour the molds too fast or something.Haven't seen a broken LST2 arm yet to know if the same problem exists.The RPM arms would be the lightweight choice,the new era arms are OK and lighter than the Ti arms but the Ti arms are by far the toughest.All good choices really.
You'd have to change hubs,bearings,outer hinge pins,cvds and hexes to LST2 to run the new arms,all of which is untested so far so i'd put some RPM arms on for now.(unless you want to contribute by testing the new stuff)
RPM is always a good bet. Plus lifetime replacement warrenty. So you break one, they send you a new set ;)
From how I understand it "read on there site" its not as simply as that, pretty much you have to prove you wasnt doing anything stupid at the time of breakage..
but I think RPM are good I know someone with 3 LST's and now a Aftershock and RPM is all he uses.
