Crt.5 Brushless Motor !!!
Page 2 of 2
nitrostarter
05.26.2009, 09:06 AM
It should be fine. The Mamba max is a very capable esc, and that motor is only going to push 105amps in short bursts, if ever.
N. Rustler conversion
nitrostarter
Find all posts by nitrostarter
17
05.26.2009, 09:08 AM
MM used to run our truggies and MT with no issue - for 3/4s use you need to use an external BEC and I always like to add an extra cap to.
Find all posts by Arct1k
18
Jason
05.26.2009, 09:12 AM
ok the max amps draw of a brushless motor like 105a it is not continuous ? only in short bursts for a few second right ?
Jason
Find all posts by Jason
19
05.26.2009, 09:36 AM
Its a guide - on average you'll probably be running at 20-30 amps
20
Jason
05.26.2009, 09:42 AM
ok cool! and now my last question if I bought this medusa 36-60 2000kv do you think I can run it on my other rc's ? 1/8 brushless truggy @ 4s ....
Jason
21
nitrostarter
05.26.2009, 09:50 AM
Definitely! the 36-6-2000 is a good choice for a buggy on 4 or 5s, geared appropriately. You can even run that in a MT like Emaxx or Revo...
nitrostarter
22
Jason
05.28.2009, 04:54 AM
do you think a medusa 36-60-2000kv @ 4s on my crt.5 would be alot overpowered ? do can hold up fine ?
Jason
23
nitrostarter
05.28.2009, 10:25 AM
It would work, overpowered and overweight maybe... You could probably get away with a smaller mAh lipo and still have good runtimes while losing weight.
nitrostarter
Page 2 of 2
Linear Mode
Switch to Threaded Mode
