Originally Posted by lincpimp
The KB has plenty of power, but has a 30mm bolt pattern and 6mm shaft. So you are stuck with making a mount and either turning the shaft to 5mm or using plastic spurs and the small selection non hardened pinions.
Go with the MMM/2200 combo. Best deal you will get.
kershaw designs' 6mm pinions are now hardened. their older ones weren't though.
