Parallel adapter
bcltoys
Parallel adapter - 06.26.2009, 08:11 PM
Can a parallel adapter be found made with 6.5 bullets.Or do i have to make my self.
06.26.2009, 08:23 PM
Nay, DIY item. I wouldnt trust a shop bought item myself, had some cold solder joints on battery charger leads so its better to do it your self, that way you get the exact length you need too. :)
bcltoys
06.26.2009, 08:46 PM
Okay so i makey my self,what size wire should i use.
06.26.2009, 09:38 PM
10g, given the size of the plugs and wires on the MMM. Use good quality lead-free solder too, or silver solder.
whitrzac
Can't catch this...
whitrzac's Avatar
06.27.2009, 12:34 AM
well, if lead causes cancer in other stats besides CA, I'm screwed
Jabe
06.27.2009, 05:30 AM
Do it like this, there is no wires to resist.
Those plugs had through holes, where i put pure copper rod and then soldered.
Thomas
Thomas's Avatar
06.27.2009, 04:55 PM
Excellent idea. How do you insulate this connector?
06.27.2009, 05:03 PM
I would use either electrical tape, or plasti-dip and brush it on.
Heres my effort, basically the same thing only with 5.5mm plugs:
bcltoys
06.28.2009, 08:57 AM
Where can you find 10 gauge wire i can find 12.
06.28.2009, 10:08 AM
Nicely done...may have to use this idea in the near future
06.29.2009, 08:01 AM
12g is alot more common and perfectly fine, but given the size of the plugs its probably better to use wire the same size as such:
http://www.amainhobbies.com/product_...e-30-Red-Black
http://www.cheapbatterypacks.com/?sid=1628787&pgid=wire
http://www.hobbycity.com/hobbycity/s..._Soft__(1mtr)_
bcltoys
06.29.2009, 06:59 PM
Thank you Mr Neil.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
