neu motor can threads gone
lind5
Angry neu motor can threads gone - 08.02.2009, 10:05 AM
hi guys well while i was bashing my brushless converted lst today i got a few back flips a bit wrong so had some heavy landings i have pulled the treads out of the end of my motor can
does any one no if i could send it off and get a new can for it
is so do you ne where it need to go im in england i did get the motor from mike but it was i while ago
any advice would be great as i cant aford another motor
thanks guys
aqwut
Brushless Heavy Weight....
aqwut's Avatar
08.02.2009, 10:21 AM
thanks guys
Send it in and get 50% discount on a new one right?..
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
08.02.2009, 10:30 AM
Just buy a RCM end plate - You can use the 2 other screw holes and gain 4 more...
Candyman2
Candyman2's Avatar
08.02.2009, 01:20 PM
either use the other 2 holes or do what i did and tap the holes out to M4
Metallover
RC-Monster Spudgunner
Metallover's Avatar
08.02.2009, 04:11 PM
Make sure to use the right screws. I thought I was using m3 screws, but they were a fraction off and I stripped the threads on my medusa without much effort. I'm getting a front endplate and new screws from mike so hopefully I'll be up and running again.
rcgrinch
08.02.2009, 04:57 PM
this is the rite way to fix it once and for all!!
lind5
08.02.2009, 05:19 PM
i was using the end plate it pulled all 4 screws out
08.02.2009, 06:42 PM
I'd drill out to 4mm then...
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
08.02.2009, 08:12 PM
I'd stop doing back flips.... Even the 4mm thread will strip eventually under that level of stress.
simplechamp
simplechamp's Avatar
08.03.2009, 01:18 AM
Yeah, just get a 4mm drill and tap. 4mm is more surface area of threads so it will be a bit stronger, but as others already mentioned it won't be bulletproof if you abuse it.
I bought a nice Dubro metric drill and tap set for pretty cheap. It has 2, 2.5, 3, 4, and 5 mm drill and taps and a decent collet-style tap handle. Or you can buy them individually. Taps are an often overlooked tool that should be in everybodies toolbox.
Metallover
Metallover's Avatar
08.03.2009, 01:39 AM
I'm assing you're running a 1521/1527 in your lst, and those are long motors. I would make a rear support once you get the threads worked out. Something that clamps on and mounts to somethng strong is ideal.
