Is there a known problem with hinge pins bending the lower rear on the batt side is the one in ?.Bent it once put a new one in and bent again don't know if it's happening when jumping and landing it just seems to happen.Could it be the batt weight.Or maybe i need to up my shock oil weight and springs.
Yes, the rear outer hinge pins on the 8ight are known to be a weak spot. Some people upgrade to Associated 1.02 shock shafts and use them to replace the hinge pins. The 8ight 2.0 has bigger pins
