07.06.2009, 05:17 AM
You look like a fat funk in the stupid shirt bondoballz...
Seriously man, get a grip. No need to flaunt your chubby bunny, you horse smacker. Seems like you like fluffin' some pork and beans.
Originally Posted by jayjay283
hobby city is rolling some 2500's for 19. I cant imagine using 8 AA's again. As part of the brushless revolution, I laugh at the bundles of batterys at Home Depot .
Smack that hoe!
In the garden dept, no less!
Fat Kid Engineering
07.06.2009, 09:10 AM
The picture is not of myself, Yes I'm big guy but I thought the picture of the T-shirt was funny ?
Who are you to tell me what's cool and isn't anyway, you have a kermit with a kalashnikov,what the hell is that ?
I changed my avatar just for you and you can smooch the right cheek.
Fat Kid Engineering
07.06.2009, 09:14 AM
Originally Posted by BrianG
If the radio uses 8 AA batteries, 3s is perfectly fine. 8 alkaline AA's is 12v nominal, maybe a bit higher when fresh. 3s lipo peaked is 12.6v.
I'm hearing you Brian, I had the regulator laying around and thought I'd play it safe with Traxxas TX.
07.06.2009, 09:23 AM
a 2100mah fit into my m11. it even has a alarm when it hits 9 volts!!!!
revo 3.3/ tekno rc bl conversion 2700kv mmm 5s
erbe mmm 2700kv 6s
slash wide trac novak hv 4.5 4s lipo
xt2 mmm 2200kv 5s
1/16 erbe 3s2p
baja 5b
summit mmm 2200kv 6s
07.06.2009, 09:54 AM
I actually thought it was funny too. But Linc's humor is sometimes... obscure. IIRC, he originally came from the UK so that should explain a lot.
"Don't act like you're not impressed."
04.30.2010, 09:22 AM
So, to do this on the DX3S, I should get a BEC. I've never actually owned or used one. Do you program it via a PC or card?? What Voltage do I set it at since my radio uses 4AA's? 4.8? yep, I'm a ri-tard. Also, I can use whatever MAH I want... as long as it fits inside right? And 2s? 3s?
ERBE: RCM 1/8 Hybrid Diffs, NEU 1515/2.5d/S MMM, 6S, Losi E-XXL CUSTOM, Neu1515 2.5d, MMM, 6s E-SLAYVO PRO ERevo Chassis w/ Pro 3.3 parts, NEU 1512, MMM, 4S.
Fat Kid Engineering
04.30.2010, 10:18 AM
Hey Goofball,
I'm using the little blue BEC here; http://www.castlecreations.com/products/ccbec.html
I think mines set at 4.8-5.0, programable via the PC just like the ESC's.
And I'm currently using 3s 20C 800mah packs and they last about 6hrs non stop. I carry a spare lipo in the case just in case, they were 6.00- 7.00 a peice at HC.
I would look for somthing with higher MAH, I will next time I need new packs.
You can easily make more in the battery compartment via a Dremel but still be able to reinstall the 4cell AA tray if needed.
To honest w/you, this mod is not for everyone. If you only use your TX say a few hours a week I'd stick with the AA Duracells and save yourself the work and hassle.
04.30.2010, 10:39 AM
The biggest issues about using lipos in a 4-cell transmitter are 1) the use of a BEC or any regulator will not let you know when the the lipo is at LVC, and 2) a BEC can fail, sending full input voltage to your radio.
Personally, for 4 cell radios, just get some low self-discharge NiMH cells. They are the next best thing compared to lipo without the shortcoming.
Fat Kid Engineering
04.30.2010, 10:43 AM
Thanks for reminding me Brian, I have some low self discharge NiMH from HC I have yet to try. If they work well in my other TX I might change everything back in my Pimp TX.
