Originally Posted by Pdelcast
Don't make the assumption that a good quality motor will also benefit from additional timing.
+1
Most of my 2 pole motors don't see more than 5 degrees of timing advance and my 4 polers are maxed out at 8 degrees.
Only my roar stuff sees more timing at times. Why, because they need it. But I don't run them much as they run way too hot.
My personal opinion between the MMM and RX8 are(I own 2 of each):
1. Tekin is much smoother than the MMM in sensorless mode.
2. Build Quality of the Tekin is better than Castle. However the Castle controller board has seen a big improvement in it's last revision.
3. Both produce monster power.
4. Castle software is much easier to use than Tekin.
5. Castle stuff is much cheaper compared to the Tekin.
6. Both have excellent service.
