08.17.2010, 02:06 PM
Patrick Tekin says you can set the initial timing just like the mambas in sensorless. Then they say you can also choose a certain amount more timing to come in at a pre set rpm to give a power boost without actually having the motor in sensored mode.
Like I have said, I am not versed on what it actually takes to make this happen I am just telling you what Tekin is promoting their Rx8 esc can do. By the way this feature is swaying guys that had swore off the Rx8 to pick them up again to see what it is all about.
