Brushless Jammin CRT Project
nl12
nl12's Avatar
Brushless Jammin CRT Project - 02.25.2006, 02:24 PM
I have finally started a new project.
Brushless Jammin CRT Truggy
So far I have purchased
Jammin crt pro kit
NRI Tomahawk suspension (I need a little bling)
Xtreme RC Racing rear uprights
Spektrum Radio
on my list to purchase:
Dace 23MM adapters
Dace skid plate
king headz Upper Steering Plate
Proline 23mm Wheels
Crowdpleazer 2 show body with $ paint job
I need input on a Brushless setup I want this truck to be a beast :028:
I will be using lipos but this will be my first lipo setup also so I need help with that too.:032: Hyperion Polyquest "Lite Storm" are these good? I want the best:027:
I have been thinking of a lehner 2250 8 turn I dont want to run more than 22.2 volts lipo though so I dont know if that motor will work for me I may need a lower turn? I dont know I need your help here.
Maybe lehner 1950 would be better?
I have access to machine shop at work and custom composite fabrication(ME)
I have never made a motor mount before but it doesnt seem too hard. I want to use a 51t mod 1 Spur like Mike sells (if it will yield appropriate gearing?) I am not sure how to adapt it though; if anyone has done this on a similar center diff help and advice would be awesome.
As I get things in and assembled I will post pictures
Thanks
captain harlock
RC-Monster Captain
captain harlock's Avatar
02.25.2006, 02:28 PM
You dont need to go near the 22 series. A 1950/9 or 10 turns will do the job just fine. Get the micro 20120 controller for your setup or the 36120.
Nice to meet you!
squeeforever
squeeforever's Avatar
02.25.2006, 02:53 PM
i wouldnt go for a 36120. if im not mistaken they have a 42000 rpm motor limit. the 3695 will do i think. also, i would go for the 2250 if funds permit. with the 51 tooth spur you will probably need a rather big pinion. so gearing shouldnt be a problem. mike can make you one if he can find the proper gear stock for it.
Gustav
Gustav's Avatar
02.25.2006, 03:42 PM
IMO it won't be near heavy enough for a 2250,a 1950 on 6s will be extreme already( go for a 1600 to 1800kv for 6s).Either a 36120 or a 3695 would be good ( no need to go over 42000 rpm) or the MGM 16024.
What's the diff ratio?
@squee,it won't need a very big pinion, to hit about 65 mph with 3.3:1 diffs and 40000 rpm is around 16/51(somewhere in that ballpark)
EDIT;nl12,get in touch with Mike for a spur adapter,he'll likely make you an adapter for the 51T spur.
nl12
nl12's Avatar
02.25.2006, 04:37 PM
The diff ratio is 43/13
Gustav I will ask mike about an adapter for the spur gear, thanks
Edit: 1950 7 turn 1791kv I may go with this if others seem to agree, I am still pondering the 22 series....... something about it
squeeforever
02.25.2006, 04:49 PM
the 1950 is a good motor for that setup but if you want insane speed and the most biggest super-d-duper motor around, go with the 2250. if i had the funds to get one i would but....
Serum
Serum's Avatar
02.25.2006, 04:50 PM
have you got experience with BL? if so, how many cells?
Dafni
Dafni's Avatar
02.25.2006, 04:55 PM
A 1950 would do, really.
On 6S, take a wind that would give you around 40mph on 6S, and you will have an awesome setup.
maxxdude1234
maxxdude1234's Avatar
02.25.2006, 05:24 PM
A 1950 on 6s could do upwards of 50mph+ IMO. But if you really want your truck to be an absolute beast, then a 2250 would be the option - personally a 1950 would be plenty for me. You will also need a hell of a controller for the 2250/8, nothing less than an MGM 16024 or bk 20150/36150.
Serum
Serum's Avatar
02.25.2006, 05:50 PM
there are a few steps in between though.. How about a 2230? it will have got a bit more torque than the 1950.. or the 2240. which is quite a beast as well.
what is your experience with BL? and with how many cells?
coolhandcountry
coolhandcountry's Avatar
02.25.2006, 06:34 PM
A jammin crt with a 2250 would totally be a beast. You may want to consider a 2250 7t I think would be better than the 8 t for 22volts. The 1950 would push it around on lipo pretty easy. 1950 8t would be a beast as well.
CrazyPhantom
02.25.2006, 06:47 PM
Project sounds awsome, Keep us updated.
Thanks,
Joe
Serum
Serum's Avatar
02.25.2006, 07:01 PM
the 2250/7 is 1691kv.. i realy prefer a /10 instead.. gives you more room for a more gentle gearing. remember that the jammin has got limited gearing options Leroy.
coolhandcountry
02.25.2006, 09:11 PM
I am taking that into account rene. The 10 doesn't start to come alive on 22volts. That is why I said a 7. It has enough torque to pull it. It is no more limiited than my truck really. You see what I am talking about when you test it. 18cells is like a good start for it on a 10 turn.
Superemaxx89
02.25.2006, 09:26 PM
why such a huge motor? The 2250 is $400? How big is a jammmin CRT?
