No assembly required. :)
The new mount is the same style as the Losi ten T - the steel bushing is attached to the motor with the included screw(m3 and m4 screws are included) and functions as the lower mount screw. If using m3 screws, the aluminum bushing is used in the upper screw slot, along with the included m3 socket screw. If m4 screws are used, then the included m4 button head is used in the upper screw slot. :)
