i would go for the flm hybrid bulkheads. your 6 spyder diffs will fit right in the bulkless system.
FLM i don't care much for there stuff i had to modify there half case for it to work with the screws it came with! :eek:
UE bulkheads would be great but they want over $500 for it i think and the FLM are $37.50 i have to buy two sets though right? What about the braces? I just noticed that the FLM say rear bulkheads the front and rear are the same right?
front and rear the different (at least stock is) but i was refering to the hybrid bulkless system which is similar to the ue vbs. its only 150 for the front and rear.
Got a link? What's the differance in hybird and a reguler bulkhead?
sure do. here ya go. only thing is you wont use the diff cases you already have. just the gears.
combo bulkless-incorperates the gear cases into the bulkheads for added strength and to save weight (uses stock gears) $120
hybrid bulkless-same as bulkless system but made to accept 8th scale gears for added durability $150
if you have the cases for your UE diffs the GA 7075 bulks are the ticket
I have a set for sale. PM me for price and details.
but if all you have is the diffs. FLM is the cheapest hybbrid bulks for 150$. I just intalled a set, I did not like the fact I had to dremel on my UE shock towers to fit
I sold my GA's and got a set of the FLM bulheads, the FLM bulkless needs some tweaking too.... (doable, but don't get frustrated when you need to work on them, though i heard they did some finetuning to them)
the FLM's are about the lightest bulks available. (and they are an absolute 1 on 1 fit, no modifications required.)
I have the hybird flm. I like them better than the seperate bulks and diff case. The flm shock towers don't require the modding to work. It is not hard to mod them if yours don't fit.
Peace!
Country
Help support the
Rc-Monster Buy here
