The Dude
11.16.2010, 08:16 AM
SO how long until castle make full sized vehicle controllers and help me set of the electric conversion market on full sized? :P
This is such awesomeness imo.
11.16.2010, 01:34 PM
Originally Posted by Desert Rc
Only 8s....really? I thought at least 10s was expected out of this XL esc.
XL HV version (up to 12S) coming in spring...
Patrick del Castillo
President, Principle Engineer
Soldermaster Extraordinaire
11.16.2010, 01:38 PM
Woot!
Any idea when / if a blower will be produced for the 2028?
11.16.2010, 01:51 PM
Yes -- a blower with 2 x 40mm fans will be available at the same time as the 2028 (and will ship with the Baja conversion combo...)
KillaHurtz
11.16.2010, 02:52 PM
Can you estimate the price spread between the XL HV version and the 8S XL version about to be released?
Will the HV XL version have the same current handling capability, or a lower-current/higher V capability for the same approx power output?
Thanks!
11.16.2010, 02:58 PM
Thanks!
The HV will have a lower current, higher voltage -- just like you said -- yields similar power output, but at higher voltage.
thanx!
Patrick
KillaHurtz
11.16.2010, 03:01 PM
Thanks for the quick reply Patrick. :)
Also, I can't find any info on the footprint of the esc anywhere yet. Does anyone have any specs? I know Chris has been playing w/ one...
Need to plan a place for it in my ongoing savage conversion. I want to cut a plate for the electronics next, and don't know how big a space to make for it :)
11.16.2010, 03:07 PM
Footprint is the same as the ICE-200 air controller. The heat sink is different, but shares the same footprint.
Technical drawing:
http://www.castlecreations.com/suppo...ix_Ice_200.pdf
11.16.2010, 03:43 PM
Patrick, Will it be opto or will it have a BEC? I believe last time it was said it was going to be opto. Thanks
11.16.2010, 03:45 PM
The 8S controller has a switching 5A BEC (with programmable output voltage,) the 12S controller is opto.
Thanx!
KillaHurtz
11.16.2010, 05:16 PM
Specs from the pdf PdC linked:
Length:3.94” (100mm)
Width:2.04” (52mm)
Height":1.2” (30.6mm)
Weight:4.56 oz* (129.4g*)
Max amps:200 amps**
5 amp BEC
Max volts:34 volts (8s LiPo/22 cells NiCad/NiMh)
Thanks
11.16.2010, 05:51 PM
Patrick,
Do you now if the conversion kit will include a pinion and if so, what tooth count?
11.16.2010, 05:57 PM
Originally Posted by NickRummy
Patrick,
Yes I do know that.
It will include a pinion -- 14 tooth. We will have option pinions of 12tooth, 16tooth and 18tooth.
Thanx!
Patrick
11.16.2010, 06:24 PM
Thanks! Any specs on the battery holder(s)? I have my 2 4s 5000 packs waiting.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
