what thickness would i need? -
12.11.2010, 09:55 PM
i found some cheap carbon fiber... and i want to make some parts for my emaxx and some other stuff... what would be the recomended thickness for stuff like shocktowers and maybe even chassis????
For shock towers, probably 4-5mm is good. For a chassis it depends if you want to do a single plate or a double-deck thing. For a plate chassis I'd use at least 4mm. If you went with the double-deck then 2.5-4mm would work depending on the design and your intended use.
Be cautious that some of the thicker CF around is actually a laminate with a foam center and a fiberglass backing.... Not all of it is, but just be aware.
I just made a 5b wing with some of that stuff. It's weird to work with.
