New CC 2028 seems to be out.
Dj_Sparky
New CC 2028 seems to be out. - 12.24.2010, 04:15 PM
http://www.castlecreations.com/products/2028_motor.html
"This motor can easily run in the 10 horsepower range." Quite a statement. This means that it can atleast produce 8000-10.000 watt?
Cody.McP
12.24.2010, 04:17 PM
Yup, it's out. I wouldn't doubt their claims, it's heavy and BIG.
I posted more pictures in the Castle 5th scale thread.
Dj_Sparky
12.24.2010, 04:27 PM
Is it only possible to order it from the CC site at the moment? Would like to order somewhere faster..
Correct me if I'm wrong, but isn't that identical to the Neu 2230? Same size and weight?
I will be ordering one tomorrow most likely, and run it on 6s til I can afford the Mamba XL. Will it run nicely on 6s? Or should I just wait til I get the Mamba XL? (Won't be that long.)
Cody.McP
12.24.2010, 04:29 PM
I ordered from the CC site and through correspondence via E-Mail, got my motor and ESC today and it was shipped yesterday (which was the first batch of shipments I believe). I don't think anywhere else you buy from will be any faster, if you can even find another place right now.
Dj_Sparky
12.24.2010, 04:51 PM
Ah, will just order from CC then. Will maybe get the ESC too. But could you tell me if the 2028 is identical to the 2230 or not?
Cody.McP
12.24.2010, 04:57 PM
It's not. Is is redesigned by Castle for better Car use I think. I think it puts out the same amount of power as it seems to be VERY similar, just a different case for the most part I believe.
12.24.2010, 05:30 PM
Castle uses the same labelling/ name system for their motors as Neu, so logic dictates that the castle 2028 is gonna be noticeably smaller than the 2230 I'd have thought:
2028 = 2.20" diameter & 4.4" long
2230 = 2.50" diameter & 4.7" long
Didnt take me long to find that info out by comparing the listed specs on the castle website of the neu & neucastle motors...
http://www.castlecreations.com/produ...rs/nm2200.html
toplakd
12.24.2010, 06:13 PM
And both motors fit info my Baja5b Brushless conversion kit :)
That is nice. Will have to order one.
Dejan
I removed my signature.
12.24.2010, 09:14 PM
it'll pull way too much current on 6s in a 5b. maybe okay in a revo
12.24.2010, 09:18 PM
10hp is 7460watts. There is no way you'll be able to put all that power to the ground. Tires would shred.
Dj_Sparky
12.24.2010, 09:51 PM
Was thinking of putting it in a GST 7.7 until I get a 5th scaler.
12.24.2010, 09:54 PM
Highest spike I had was 7hp
BIG-block
12.24.2010, 10:56 PM
I think you might have had a few too many drinks there paralyzed. 2028 in a Revo? WTF? You had way too many.
I have seen what the 1717 does in a GST 7.7. Crazy!!!!!
Semi Pro
Semi Pro's Avatar
12.25.2010, 01:04 AM
im putting one in my lst xxl so a revo sounds even more fun with that kind of power, dont forget this is rc monster
Dj_Sparky
12.25.2010, 04:12 AM
What are you planning for a mount? Retrofitting a Baja mount or making your own?
