Popoxx
Sapere aude
Popoxx's Avatar
10.24.2010, 11:53 AM
My maxx looks like this currently :
I weighed it, here are the results FYI :
- Body + Clips : 156g (0.34 lb)
- Protek Lipo : 310g*2 = 590g (1.30 lb)
- Mashers tires + Maximizer rims : 1385g (3.05 lb)
- E-Maxx chassis : 3785g (8.34 lb)
Total w/o lipo : 5326g (11.74 lb)
Total w/ lipo : 5916g (13.04 lb).
To be continued...
Popoxx
Sapere aude
Popoxx's Avatar
01.06.2011, 05:12 PM
Here is my next upgrade :
It's the new HPP wheel hub, soon available. No more slope normally ! I will test it soon (I will post pics at least, my maxx hates winter...).
I'm not really worried by the slight axial slope (look at my driving style...) but I want the best for my maxx
justchil
01.12.2011, 04:42 PM
Nice thread. I'm down a similar path of buying too much stuff to try out what works for me.
Trying to figure out if I can buy HPP parts from a US dealer somewhere...
brushlesswonder
03.22.2011, 06:23 PM
wow POP!, great truck man. seriously love the maxx. that thing is beast :D
Popoxx
Sapere aude
Popoxx's Avatar
03.25.2011, 05:42 PM
HPP parts are only available on the HPP online store for the moment
Popoxx
Sapere aude
Popoxx's Avatar
03.25.2011, 05:43 PM
Thanks
Popoxx
Sapere aude
Popoxx's Avatar
10.15.2011, 10:56 AM
I finally found the time to install the HPP wheel hubs !
Here is the idea :
Here is the result, step by step (as usual !) :
Washer, axle pin, thread lock.
Hub.
Center nut with grease.
Wheel !
And tadaaa :
Bkack wheel nut.
Desanodized wheel nut.
And of course, absolutely no slop
To be honest, I only installed this wheel hub on my E-Revo (http://www.rc-monster.com/forum/showthread.php?t=24654) for the moment, I want to compare the reliability of both wheel hubs (Traxxas vs HPP) before buying a new set for my maxx.
Popoxx
Sapere aude
Popoxx's Avatar
02.23.2012, 07:40 AM
I love my maxx
My setup is perfect for bashing, I wanted to reassert it
During the last session (sept or october I think) I landed on a rock and I bent one of my chassis brace :
And I lost one UE standoff :
^It's more problematic because I don't think UE sells them separately and it's hard to do business with Robin, he doesn't like shipping outside USA. I will try and if it doesn't work I find a home-made solution.
Another thing I have to find are sturdy body posts/clips easy to replace and a solution to avoid breaking bodies every session... I have some ideas, I will post the results one day. These mods aren't the most exciting but the main upgrades have already been done !
Long life to E-Maxx
Buzzsaw46
02.23.2012, 09:03 AM
Now thats some hardcore bashing right there! Truck is looking good Popoxx.
Popoxx
Sapere aude
Popoxx's Avatar
02.26.2012, 06:25 PM
Thanks man ! I'm waiting spring to make some new vids !
Popoxx
Sapere aude
Popoxx's Avatar
09.10.2012, 02:05 PM
I'm always addicted don't worry My maxx is almost fixed, I just need an UE shock standoff.
What's new ? :
- Ejector pins :
I use Berger Tools pins now, this supplier can cut them to the length I need (3.06") and they are sturdier than the Plastixs pins I used before (I can't cut them with a bolt cutter !).
The ejector pins can't move thanks to the bumper mounts and skidplate. "Plug and play" :)
Front
I can't replace the front lower hinge pins because of the shape of my skidplate. I keep using Lunsford hinge pins here.
Rear
- Chassis braces : I replaced the bent chassis brace with a new one and 1offrc anodized it (fast and great job).
- Body posts : new ones from RC Raven :
With HPI body clips (really hard to bend !). RC Raven nylon seems similar to RPM nylon so I hope these posts will hold out. UE posts included with the shock towers aren't a direct fit (they have to be cut/drilled, boring... ).
Popoxx
Sapere aude
Popoxx's Avatar
- Body protection : I cut pieces of lexan from a Parma clear lexan sheet (.030") to protect the body (clips always destroy the body holes during hard landings ).
Now I need time to test these mods. Last time I run my maxx was in September, 2011...
Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
09.29.2012, 01:37 PM
POPOX: I'm not sure which bellcrank posts you used, but I suggest you order a set from the UE Store...they are 7075-T6 Aluminum instead of the 6061-T6 that Traxxas uses, and are far stronger! They are the ones used in the UE Gen4 Servo-Saver, but will work in any Maxx Steering System!
-Chad
PM ME IF YOU HAVE THE BELOW:
Popoxx
Sapere aude
Popoxx's Avatar
10.04.2012, 06:54 AM
Thanks for the info Chad, I often bend these posts so it's a great idea
Chadworkz
Chadworkz's Avatar
12.29.2012, 08:37 PM
Anytime man, I had the same problem, but not anymore! :)
Sorry it took so long to reply...a drunk driver hit me a couple months ago, re-injuring my already broken back, putting me in the hospital for a while.
-Chad
