CF G2 with low CoG
agw
CF G2 with low CoG - 11.20.2012, 08:50 AM
After six years I decided to start tinkering with my old CF G2 Gorilla Maxx chassis.
I really never liked how the Plettenberg Bigmaxximum sat hi and off center so I decided to go the Center Diff way after much reading on this forum and bugging the hell out of Mike
In the end after having spent hours designing a weak mount, Mike convinced me that his universal mount was the best (easiest and most effective) way to go.
Here is the (almost) final product geared way too high but hey, if ain't broke...break it.
ID:	10543   Click image for larger version
ID:	10544   Click image for larger version
tinuss
tinuss's Avatar
11.20.2012, 06:26 PM
Looks good and a Sexy motor !!!!
Ralf
agw
11.20.2012, 09:55 PM
Ralf
As they say...age makes you sexy ( I think I just made that up for my own benefit).
Here are some more pics of the (almost) final product...
PS. The gearing is WAY too high, I barely hit 8,000 RMP and look at the ballooning.
ID:	10546   Click image for larger version
ID:	10547   Click image for larger version
Gearing Calculation
agw
Gearing Calculation - 11.20.2012, 10:08 PM
As I said earlier....way too high... 102 MPH???
Differential Ratio: 2.85
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 42
Pinion Tooth Count: 15
Total Voltage: 19.50
Motor KV: 2600
Tire Diameter (inches): 4.7
Tire Ballooning (inches): .35
Motor Current Draw: 100
Motor Coil Resistance: 0
Spur/Pinion Ratio: 2.8 : 1
Total Ratio: 7.98 : 1
Tire Circumference (inches): 16.96 inches (430.9 mm)
Rollout: 2.13:1
Total Motor Speed: 50700 RPM
Vehicle Speed: 102.07 mph (163.95 km/h)
Effective KV Value: 2600
KT constant: 0.52 oz-in/A
Motor Torque: 0.27 ft-lbs
Final Torque: 2.16 ft-lbs
Final Power: 1950 watts (2.6 HP)
Dafni
Dafni's Avatar
11.21.2012, 07:43 AM
Nice to see people are still using that setup! I remember when that idea was the latest and greatest.
Maybe you should instal truggy diffs to get the ratio up? Or just run that motor on 4S??
Daf
agw
11.21.2012, 08:32 AM
Daf
Good point but at this point I think I'm going to strap a GPS to it and see how fast it really goes until something explodes! Then try again...
I'm looking for smaller wheels/tires for a straight run on asphalt; does anyone have any suggestions?
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
11.21.2012, 10:30 AM
if you have 17mm hexes, you can use wheels/tires intyended for the Inferno Gt and similar buggy-based road cars.
Nice to see your still kickin' Dafni!
agw
11.21.2012, 11:21 AM
Good idea Mike. Thanks for the tip.
Klausen
Brushless G-maxx
Klausen's Avatar
11.21.2012, 02:24 PM
Looking great. Cool truck with a cool setup.
agw
11.21.2012, 04:25 PM
I like the prolines road rage but they are too wide.
Better going with something like this as Mike suggested:
http://www.amainhobbies.com/product_...ith-Inner-GT-2
BTW I took the truck for a test run and there was a little cogging but barely perceptible. Went up to 11,000 RPM which was about 23 MPH and felt crazy fast but I loved how the front was lifting without loosing contact with the ground.
11.21.2012, 09:57 PM
Good looking truck. Is that a schulze controller?
agw
11.22.2012, 12:10 AM
Yes it is. 18.97KW with a BEC attached on top. Somhow I have not yet been able to "fry" it...I'll keep trying
Dafni
Dafni's Avatar
11.22.2012, 09:55 AM
With a setup like yours I think the Schulze is doomed.
Stay away from the roadrage tires on a highspeed setup like this. Pizzacutters was the word back then.
I would go the way Mike suggested, 17mm hex and buggy wheels/tires.
Yo, cheers Mike, good to know we're still here.
agw
11.23.2012, 11:28 PM
Since today I was able to take the truck out for a spin (video to be posted after edit) I was also able to un-glue the front tires after a couple of wheelies...
The wheels I have now are all 14mm hex, could I just get a 17mm hex wheel with the appropriate pin or would that not work for some reasons?
I believe the CVD I have are MIP (old original not spline).
Klausen
Brushless G-maxx
Klausen's Avatar
11.24.2012, 01:36 AM
I run Traxxas 17mm hex's with Proline Badland, on the original shiny 2,5 MIP cvd's. I had to mod the Traxxas hex's a bit by drilling from the backside, to make them go far enough into the cvd.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
