I've been working on this build for a while now, and its not done yet, but I figured I would share what I have so far.
I'm building it to be a basher, to take the abuse, and to look cool of course
I guess a list of parts is in order, so here we go:
- FLM Center Chassis & Braces (to be replaced with UE's new HV Lightning
... when available of course)
- Complete UE EXT Suspension
- Titanium Tierods
- FLM Hybrid Bulkhead Gearboxes
- Ofna Hyper 7 Spider Diffs
- UE Steel 6mm CVDs & Drive Cups all around
- UE Monoblock Chassis Extension
- Stamped 120gm Titanium beadlock wheels w/custom hex adapters
- IMEX J-Hawg Tires
- UE Supershocks (freshly rebuilt)
- HCR Titanium Front, Center & Rear skids
- RD Logics Trans Case
- FLM Low CG Motor Mount Plate
- Steel trans idler gear
- onclebens custom 145mm rear center stainless steel dogbone
- Gregers custom knucklhead wing mount
- MBX6 Wing stay & Wing
Still to come:
- Plastix ejector pins to replace the Titanium hinge pins
- UE Gen IV Servo Saver to replace the craptastic look-alike I had just laying around
- UE Hardened Steel Pillow Balls
- Brushless Motor & ESC
- Spur & Pinion
Anyways, on to the pictures
UE 6mm CVDs courtesy of gumleguf, thank you sir!
HCR Skids courtesy of blazers
-Travis
