Do Epic Sh!t
G4 Widetrac Build -
06.18.2013, 02:02 PM
Adults are just kids, with money.
Common sense, is not so common.
Do Epic Sh!t
06.18.2013, 02:03 PM
Do Epic Sh!t
06.21.2013, 12:10 PM
The G4 has been monoblock'd.
It had to be done. Just didn't look right without it. Plus, the rear center bone that I got with the chassis is made for use with a mono, soo.... I guess it had to be done  lol
Took some careful dremel work (didn't turn out perfect, but not bad for being done by hand)
-Travis
06.23.2013, 11:53 PM
Awesome build!
Do Epic Sh!t
06.24.2013, 10:25 AM
Thank you sir
Got this purdy new shell for it in the mail over the weekend
-Travis
Do Epic Sh!t
06.27.2013, 08:44 AM
-Travis
Do Epic Sh!t
06.28.2013, 10:33 AM
5/16" Aluminum round stock for custom body posts
And some aluminum set screw collars
They ended up a little long, so I need to cut them down still
-Travis
Do Epic Sh!t
07.02.2013, 02:43 PM
Thanks to Justinbolin, I have a purdy new servo saver for this truck
And because I like to make what I already have work (and because I'm too impatient to wait for parts), I modified a set of TRX 7075 Tie Rods for the front. I removed the double threaded ends, tapped the tie rod tubes out to 8-32 to accept some cut down ss screws so I could attach the plastic rod ends. By eliminating the original double threaded ends, I was able to shorten the tie rods just enough for them to be the perfect length.
Now I just need to de-anodize them so they match the rears.
-Travis
07.02.2013, 07:07 PM
Checkout Lunsford grinder Ti links - They look much better and are much stronger.
Do Epic Sh!t
07.03.2013, 01:56 PM
I hadn't seen those before, but you're right, they're nice and clean looking.
I will probably stick with the TRX aluminum ones for right now, just because they work and they should be pretty stout...and I have plenty of electronics to spend $$ on first, haha
-Travis
UE Supermaxx Addict!
07.07.2013, 11:30 AM
One Comment and two questions:
Comment: You have built and absolutely amazing truck, even if you didn't buy the knuckles from me, lol...but seriously, it's gorgeous!
Questions:
[1] Did you make/mill that wing-mount for the new MBX-T Wing
yourself, or did you buy it somewhere? If you boight it, where?
[2] I guess this is more than 2, heh...you did and damn good job
modifying that Mono-Block for the G4 Chassis.
-Chad
› PM ME IF YOU HAVE THE BELOW:
› VBS, CVDs, GM Single-Speed, OTB, Ultramaxxed, Super6, Strobe, Sprong, CNR Brake, UE Hex, DUH Towers, Predator, Blackbird, GA Blue Screws, HCR F/R Skids & Mutant
07.07.2013, 01:31 PM
Do Epic Sh!t
07.07.2013, 02:00 PM
Chad, thanks for the compliments on the truck!
CerberusVI got the wing mount question answered for you.
And thank you on the monoblock mod, it took me a while to do, but it fits perfectly!
-Travis
Do Epic Sh!t
07.09.2013, 04:00 PM
Well, the original center diff mount plate I got with this chassis was pretty thick, and stuck the RCM mount up high enough to cause the rear bone to interfere with Gregers' custom G4 brace. So, I robbed the center diff mount plate I'd originally made for my Predator truck (before I got one of Gregers' custom center diff mount plates, which I am now using on that truck), and I modified it to work for this truck, as its about 1/4 the thickness of the plate I got with the G4, and lowered the diff down where I needed it to be for the rear bone to clear the center hole on Gregers' custom brace.
Cut the plate down a little so it fit in between the two chassis braces
However, it turned out using the thinner plate was still not enough. The RCM mount was still sitting a little high. So, I cut about 4mm or so off the bottom of the RCM mount legs to bring the diff down even farther (and I slipped some stainless steel 16mm shims in to take the slop out of the diff)
And since I cut some material off the RCM mount legs, I had to add a slot for the spur to stick through the bottom
Drilled some mounting holes in the chassis for the new plate
And mounted it all up
With the center diff mount much lower, the bone now clears the top of the custom G4 brace
-Travis
07.10.2013, 06:21 AM
Awesome! Too many people are so a-scared to modify their parts. You just gotta man up and do it!!! In this case, Wheelman up and do it!
