lighting diffs for e-maxx
steveo
lighting diffs for e-maxx - 08.05.2006, 02:15 PM
can you guys clue me in on these diffs, i need to up grade and i liked that the gear ratio was lower
squeeforever
squeeforever's Avatar
08.05.2006, 03:03 PM
First off, there great diffs. Especially for the price. Are you talking about the standards or the Pro's? The Pros are good for a truggy but would require VERY tall gearing. I recommend the standard with the FLM Hybrid bulkheads.
steveo
08.05.2006, 03:33 PM
do you know the ratio for both , i saw that there was two different item #s for the diffs mike is selling with no ratio, i'm tired of stripping rrp gears, are they sealed for diff fluid,also i mostly do bashing and run big tires so the lower ratio gears would be best , but could i gear it for speed as well
thanks
coolhandcountry
coolhandcountry's Avatar
08.05.2006, 03:49 PM
Pros are 4.3 to 1
the others are 3.31 to 1
Peace!
Country
Help support the
Rc-Monster
Buy here
squeeforever
08.05.2006, 06:17 PM
The Pro's would be to low either way. The standard buggy diffs are the way to go. The only reason to get the Pros is if your running a center diff. BTW, what setup are you running?
