Puttinstankonia
09.19.2006, 02:45 AM
I tried charging the batteries under the NiMh setting just to bring the voltage up and it worked but for some reason my charger wont go past .1 amps... or at the most it will get to 1 full amp
danverz
09.19.2006, 08:06 AM
Hi,
if you charge at .1A probably you reach the imposted time limit on the triton,
so the max charge you'll be able to put in with theese settings is 1A.
Just try to remove the time limit, and try to set an higher delta peak.
Ciao,
Daniele
Procharged5.0
Procharged5.0's Avatar
09.19.2006, 11:22 AM
Puttinstankonia,
Love the name man. Too funny!
coolhandcountry
coolhandcountry's Avatar
09.19.2006, 01:14 PM
did you try the 3s setting? It will charge the batts to a 12.6 volts. Then you can swap to a higher cell that you have. That is what another person did.
neweuser
neweuser's Avatar
09.19.2006, 02:23 PM
Where did you get your batts from. My charger (hyperion) kept saying the same thing! "output voltage too low" when i tried to charge them in single packs. And it's suppose to charge at 7amps, but only would charge at 4amps. Then, when i tried to charge them in series, i got the error message "output voltage too high". I also run the quark, wondering if that has anything to do with it????
Puttinstankonia
09.19.2006, 05:16 PM
I tried charging at 12.6 and it said it was still too low so i took the advice of Brian G and charged them on NiMh just to get the voltage up and that worked so then i took your advice and charged at 3s and then 4s to peak and it worked fine just took forever to charge at .1-1.0 amps
Oh yea thanks for the name compliment ill have some pics up soon
neweuser
neweuser's Avatar
09.19.2006, 05:24 PM
Make sure to balance them!!!
